20 Most Recent
Danby DMW1158 Microwave Oven Questions & Answers
Danby Designer 1.1 cu.ft. Microwave
Weird that it worked when you left then not. Have you had the lights inside of your house dimming off and on?? It could mean a bad neutral connection to your house from the power pole. That can cause the low voltage transformer on the timer board to burn out. So the fuse in the unit will not even blow but still kill the Low Voltage transformer. If sounds possible call your power company to do a "load test" on the incoming power lines to your house.. They don't typically even charge to do that. They take out your meter and put a tester in that spot that tests the supply to your house.
...have Danby 1.0 cu. ft.
When talking about "Power Level", there is a misconception that the cooking power is being adjusted. This is not the case. The user is actually adjusting the duty cycle of the Magnetron. For instance at 30%, the Magnetron will be turned on for 20 sec. and off for 40 sec. A loud 60 cycle hum is usually caused by a shorted Magnetron. Thus the unit is not economically repairable.
I would like to Put my danby microwave warranty and registration
the to register --warranty details and equipment serial number will be on the warranty card that came with the equipment
follow those instructions
or
google the manufacturers site click on the " contact us" tab , fill out the details and in the comment box type in the equipment details , date of purchase , serial number , model etc and request that it be registered in the company warranty records
