20 Most Recent Disney Princess Toyota FJ Cruiser 12-Volt Battery-Powered Ride-On Questions & Answers
what is the model number of this disney princess jeep
I have ec1126 and that is not populating parts
Disney Princess... | Answered on Sep 06, 2016
I get mine for all my restorations at the u pull it yard - I take my old one off and take it and the tools to the yard. Find a nice one and remove it. usually cost me about $25 without the air bag. Done this many times. Watch out tho, it has to be an exact replacement - some air bags and horn buttons are different!
Disney Princess... | Answered on May 16, 2016
Sound like a BAD connection between BATTERY & MOTOR
Disney Princess... | Answered on Jan 06, 2016
You can buy new wheels for about $10 each on motionTrendz. Here is a link to the wheels you need:
FJ Cruiser Wheel Princess Chrome
Disney Princess... | Answered on May 01, 2014
check the battery is ok or not
Launch scan tool
Disney Princess... | Answered on Dec 05, 2013
use a 12 volt trickle charger with overcharge protection
Disney Princess... | Answered on Sep 30, 2013
hi ,i need a pin code to nats...
vin :SJNBFAP11U0594153
NISSAN PRIMERA 2001 1.6
Please Help..
Vehicle Parts &... | Answered 24 hours ago
same as jupiter all good
Vehicle Parts &... | Answered on Nov 08, 2019
Don't click on spammer Victoria Archer, as FIXYA doesn't remove most spammers automatically. Volunteers answer questions without charge.
https://www.scorpionauto.com/car-remote-alarm-immobiliser-scorpion-sa30/
Contact information.
https://www.scorpionauto.com/contact/
Vehicle Parts &... | Answered on Oct 25, 2019
Tip
Longer lasting engine maintenance
Your engine will last a lot longer as far as the main engine components if you 1)change your engine oil at vehicle recommended mfg intervals.TIP: if you live in hot climates you should change your oil more often and at less miles .2500 to 3000 ml. every 3 months because the climate the hot temperatures break down oil viscosity at a higher rate thus needed more frequent oil changes for the best engine engine lasting performance.2) always use the recommended weight example (5/30w)TIP: Also for best results the recommended rating of the oil for example on the back of the oil bottle is a rating 2 or 3 letters in a circle .Older vehicles use a different rating than newer vehicles and some times they are not interchangeable this information should be available at your local parts store.3)TIP;: Always use the recommended (brand) oil filter.With the way cars are now especially ones with overhead cams and chains ,aftermarket filters might not supply the same pressure aspects of the original oil filter, So as far to have less or more pressure than that is needed to maintain these components correctly with the correct pressure.
Thanks hope this helps
on Oct 22, 2019 | Vehicle Parts & Accessories
check compression
Vehicle Parts &... | Answered on Oct 14, 2019
if you lost all compression on all cylinders at the same time check your timing belt or timing chain. good luck .
Vehicle Parts &... | Answered on Oct 09, 2019
It is suitable for a number of vehicles, as it includes long bays for vans, and short bays for other vehicles, and with minimal alterations it is suitable for installation in any vehicle model.
It offers more storage capacity for odd sized items, and represents easy inventory control, by reducing the need for overstocking expensive items in your work vehicle.
The system is fully adjustable.
Vertical adjustments can be made to gain maximum use of your vehicle height, while horizontal adjustments can follow the contour of your van, to allow for more aisle space.
The rak-a-van system provides maximum working space and fast access to all items, and optimises productivity.
Tradesman Fitouts 4WD Sydney
Vehicle Parts &... | Answered on Sep 26, 2019
Vehicle Accessories is the leading discount store for automobile accessories. We offers you various cars and bike accessories such as tyre and wheel, replacement parts, auto spare parts , vehicle exterior and interior care services from the best brands at the most affordable rates. The company offers a wide selection of car products, including auto electronics, cleaning materials, oils and fluids.
Vehicle Accessories is an online store that offers all the latest in car parts and accessories at reasonable prices. You can find everything you need to customize your car to make it truly your own.
This Vehicle accessories shop online sells everything under the sun to deck out your car in the best way that fits your needs. If you're getting ready for the summer, you can find all the essentials like waterproof seat protectors, connectors and cables to connect your kayak or surfboard to your car, and bike racks so that you can get out and enjoy the fresh air.
Vehicle Accessories has several locations in Australia where you can buy accessories and products for your car in addition to a full range of services to keep it running at top performance.
Car Accessories Sydney
Looking for the best vehicle accessories installers from Melbourne Contact Local Mechanics Melbourne for better results.Local Mechanics are one of the premier auto repairer groups bringing together customers and their local mechanics across Australia. All mechanical services are performed by highly qualified and licensed mechanics.
Disney Princess Toyota FJ Cruiser 12-Volt Battery-Powered Ride-On Logo
10 questions posted
Top Walt Disney Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Walt Disney Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Walt Disney Vehicle Parts & Accessories
Most Popular Question
disney instruction manual
  • Vehicle Parts & Accessories
