Hello, what I have found is the most common cause of water leaking out of the bottom of the capresso team coffee maker is a leaking silicone hose that runs to the boiler (See the photo below with the split in the hose). The replacement silicone hose needs to be safe for beverage dispensing, food & dairy processing, taste and odor-free, with a temperature range of -75? to 350? F. All you need is a sharp pick, a phillips screwdriver, and a pair of needle nose pliers. Remove the four rubber pads on the bottom using the pick. Use the screwdriver to remove the six screws holding the bottom plate on. Remove and replace
"BOTH" hoses using the needlenose pliers to pinch the hose clamps. Better to play it safe while you have it apart. If one is bad the other is likely not far behind. I hope this helps.
