20 Most Recent
Electrolux EL6984A UltraSilencer Green Canister Vacuum Cleaner Questions & Answers
Cord won't stay out, it keeps going back in
when pulling the cord out, it should 'keep' it that spot if you pull a certain direction, cant recall if it is up, or down, left or right, and pulling it opposite direction releases the cord again
How do I take apart my electrolux ultrasilencer green vacuum to fix the retractable chord?
I would not recommend doing that. Take it to your local vac shop. They may or may not be willing to repair it. These machines were not built to repair. They are considered disposable. I have repaired these at my store but it is a very tedious task to get it apart without breaking all the tiny plastic tabs. You should give the local shop a chance before trying it yourself. They are better equipped for it.
Electrolux h5005
Can't find the question for the Electrolux vacuum cleaner H5005, but I have one of my own: Where can I get a wheel for this model?
Replace belt on Electrolux Epic 2500 SR Upright
1. Start by removing the screws that secure the bottom plate of your vacuum. 2. Once the bottom plate is removed, you will find the belt inside, as well as the belt pulley and drive wheels. 3. Disconnect the belt from the belt pulley. 4. Align the new belt over the belt pulley and drive wheels so that the teeth of the belt match up with the grooves on the pulley. 5. Wrap the belt around the pulley and drive wheels, and then reattach the belt to the pulley with the supplied clips. 6. Reassemble the vacuum and you're done!
