20 Most Recent LG LFX25950 Stainless Steel (247 cu ft) Side by Side Bottom Freezer French Door Refrigerator Questions & Answers
Problem with LG LFX25950TT Refrigerator (Freezer portion)
It is likely to be either the circulation fan in the freezer or the defrost element. Check the fan is running( you can usually hear it stopping as you open the door, some still run) otherwise it could be a defrost problem, if the element doesn't work the rear fills up with ice and the air cant flow. Both are behind the rear panel of the freezer.
7/8/2013 3:42:09 PM • LG LFX25950... • Answered on Jul 08, 2013
Error code if
IF is an error that states your icemaker fan is not running. You just need to order and replace the icemaker fan behind the back panel inside the freezer to fix the issue. Here is the part to order.To replace the fan: Remove the freezer shelf. Remove the plastic guide for slides on left side by unscrewing phillips head screws. 2) Pull the grille forward and remove the grille. 3) Disconnect wire harness of the grille. 4) Remove the scroll assembly by loosening 2 screws. Replace the duct assembly.
12/1/2012 8:51:24 PM • LG LFX25950... • Answered on Dec 01, 2012
Water is squirting out of the back when ever you
Yes,remove it.
The water valve is located there as is the water line.
The valve is broken or a water line is broken.
8/9/2011 6:18:47 PM • LG LFX25950... • Answered on Aug 09, 2011
Lg refrigerator gr-282 mvf NOT COOLING
Try pulling the cover off in the back of the fridge and see if the fan is still operating when you push the light sensor switch in but hold it down for at least 10-20seconds to see if it starts.
3/28/2024 12:01:33 AM • LG Refrigerators • Answered on Mar 28, 2024
2answers
LG GR-P197WVS. How do I keep the refrigerator side from freezing?
Fridge freezing up- and no fan or air circulation: AT TIMES The fan usually stops working due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature. May also need to check the defrost timer, The defrost timer is usually found behind the front grill "toe kick" of the refrigerator. Or in the fridge compartment near middle top section. u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad? Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next. Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance.. Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS . Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit? ALSO CHECK THE AIR FLOW VENT SYSTEM and THERMISTORS At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area! THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 1300 ( give or take 150 ohms) ohms is required God is so good: so this is why I give free advice so please thank him not me. lg-gr-p197wvs-prevent-refridgerator-iizpua1124tc1voeqjalmrl5-3-0.jpg lg-gr-p197wvs-prevent-refridgerator-iizpua1124tc1voeqjalmrl5-3-2.jpg lg-gr-p197wvs-prevent-refridgerator-iizpua1124tc1voeqjalmrl5-3-5.jpg lg-gr-p197wvs-prevent-refridgerator-iizpua1124tc1voeqjalmrl5-3-9.jpg lg-gr-p197wvs-prevent-refridgerator-iizpua1124tc1voeqjalmrl5-3-14.jpg lg-gr-p197wvs-prevent-refridgerator-iizpua1124tc1voeqjalmrl5-3-20.jpg
3/17/2024 4:40:23 AM • LG Refrigerators • Answered on Mar 17, 2024
2answers
LG fridge LFC25760ST beeps and increases temperature intermittently when door is opened.
1/2/2024 12:40:07 AM • LG Refrigerators • Answered on Jan 02, 2024
My LG refrigerator is flush to the wall, and I can't remove the bottom drawer that has a spill under it. How do I clean it?
You just pull it out 12" so the door will open fully.
10/23/2023 7:38:06 PM • LG Refrigerators • Answered on Oct 23, 2023
7answers
My LG fridge won't stop beeping? The doors are closed properly. We are getting 3 beeps every 30 seconds! Help....
Happened to me, too. I hadn’t placed the top hinge covers back on after removing the doors to move the fridge. The sensors that tell the fridge the doors are closed are in the hinge covers.
10/21/2023 10:54:08 PM • LG Refrigerators • Answered on Oct 21, 2023
Hi I'm using LG model GR-J268LSJV not cooling at all showing f d5 as an error
Error code list is given on LG Official website LG Refrigerator - Error Code List ' LG USA Support Error code P5 is not listed in error code list. Please mention exact error code.
10/11/2023 12:31:56 PM • LG Refrigerators • Answered on Oct 11, 2023
Does the LG LFXS28968S have a defrost timer?
It appears that it doesn't. It appears to have a Thermistor and a heater. That would mean timing comes from the control board. https://www.google.com/search?q=LG+LFXS28968S+defrost+timer ..
10/8/2023 9:13:16 PM • LG Refrigerators • Answered on Oct 08, 2023
LG Washer / Dryer Combo Model Number WM3987HW. Won't Turn On.
Do you have a test meter to check if the power button is working and has continuity? My advice with a suspected control board is always to get professional diagnosis due to the cost or control boards. It would be a shame to buy one and find it doesn't fix the issue. ..
9/6/2023 8:39:24 PM • LG Refrigerators • Answered on Sep 06, 2023
LG REFRIDGERATOR LFX25973ST / 06 : DOOR ICEMAKER EAU61843013: NOT DUMPING ICE INTO BASKET
unplug the power for 10 minutes then plug it back in. this seems to work on mine,
8/15/2023 5:37:05 PM • LG Refrigerators • Answered on Aug 15, 2023
Interchangeable lg ice maker models
While the LG AEQ57518210 and LG 5989JA0002Y ice makers may appear similar and have the same adapter, it's important to note that using a different ice maker model than the one specified by the manufacturer can have potential risks and consequences. Refrigerators are designed with specific components, including ice makers, that are tested and engineered to work together as a system. Using a different model ice maker may lead to the following issues:
  1. Compatibility Issues: Even if the adapter fits, there might be compatibility issues between the different ice maker models and your refrigerator. The electrical connections, mounting points, and water supply might not align properly, causing installation difficulties or functionality problems.
  2. Performance and Quality: Ice makers are designed with specific performance and quality standards. Using a different model ice maker might lead to subpar ice production, inconsistent ice quality, or even no ice production at all.
  3. Leakage or Water Damage: Improperly fitted or incompatible ice makers could result in water leakage, which can cause damage to the refrigerator, flooring, or surrounding areas.
  4. Electrical or Wiring Issues: Different ice maker models might have different electrical requirements or wiring configurations. Mismatched electrical connections could lead to electrical problems or even pose safety risks.
  5. Voiding Warranty: If your refrigerator is still under warranty, using non-standard parts like an incompatible ice maker might void the warranty.
  6. Long-Term Reliability: While the initial cost savings might be tempting, using an incompatible ice maker could lead to long-term reliability issues for your refrigerator.
8/5/2023 10:17:31 AM • LG Refrigerators • Answered on Aug 05, 2023
2answers
My LG refigerator LFXS28968S stopped working. How do I know if the compressor is bad?
ck out these sites.... https://www.repairclinic.com/ProductDetail/2155228?symptoms=51 https://www.appliancepartspros.com/parts-for-lg-lfxs28968s-00.html They both have parts and videos on installing them. Before you go throwing parts at it, give them a call at their 800#s to talk with a tech. I'm not affiliated with them. I just have used them to repair appliances in our home and rental units. And always found them helpfull. Best to you.
8/2/2023 3:17:16 AM • LG Refrigerators • Answered on Aug 02, 2023
Arctic Wind Refrigerator Model ASXS1207
Call for Service. If the compressor is warm, it means it is working. It probably just needs refrigerant gas. Unlikely to be a relay if on the compressor, but a Start/Run Capacitor. It is a $2,000 appliance and worthy of repair https://www.google.com/search?q=Arctic+Wind+Refrigerator++ASXS1207 ..l
6/12/2023 10:27:17 PM • LG Refrigerators • Answered on Jun 12, 2023
LG Refrigerator Not Getting Cold Enough Both Fridge and Freezer
It could be from the condenser coils are dirty, bad ventilation,not installed correctly,broken or dirty seals for the gaskets, food storage that is not organized.Or the internal parts are broken.Yes it could be possible that your fridge had quit working and you may need to buy a new one.
5/30/2023 7:52:29 AM • LG Refrigerators • Answered on May 30, 2023
LG LFX25950 Stainless Steel (247 cu ft) Side by Side Bottom Freezer French Door Refrigerator Logo
16 questions posted
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
LG Refrigerators
  • LG Refrigerators
Most Popular Question
water squirting out back when ever
  • Refrigerators
