20 Most Recent Electrolux EW28BS71IS (278 cu ft) Bottom Freezer Commercial French Door Refrigerator Questions & Answers
2answers
Electrolux EI26SS55GSO power failure alarm; how to disable
Hi Randy - The power failure alarm can't be complete disable, but you can try resetting it by pressing the ALARM OFF icon. Other modes may be turned off until the alarm is acknowledged. The power fail alert is turned off and the refrigerator should resume normal operation. However, if the alarm continues to go off after you have unplugged or flipped the household circuit breaker for 30 seconds contact a professional to have the main control board diagnosed.
10/3/2017 3:47:23 PM • Electrolux... • Answered on Oct 03, 2017
0answers
0answers
Plastic smell back of freezer
Good Afternoon friend, thanks for your post!
From the information you have provided you are receiving a plastic smell inside the back of your Electrolux refrigerator. I can provide some basic troubleshooting steps to help clear out any unwanted odors. You can clean the walls with warm soapy water or warm water with baking soda mixed in. You may also use lemon juice to wipe the interior walls the citric odor can help combat smell. Another thing to use is a pan of kitty litter or a pan of charcoal (not the self-starting kind). I hope this is helpful. -Matt
3/4/2015 8:08:24 PM • Electrolux... • Answered on Mar 04, 2015
Electrolux diagnostics for refrigerator with freezer on bottom
Hey friend, thank you for your post! Based off the information you have provided your Electrolux refrigerator is running but not cooling. It could be possible that your refrigerator is stuck in a defrost mode. I would suggest resetting your appliance which can be done by flipping the household circuit breaker for roughly ten minutes. If that does not correct the issue I would seek assistance from a professional to come repair your appliance. -Matt
8/20/2014 7:42:10 PM • Electrolux... • Answered on Aug 20, 2014
0answers
Ice maker stuck
Be the first to answer 3/18/2014 4:52:29 AM • Electrolux... • Posted on Mar 18, 2014Be the first to answer
The past 3 nights I've had power failure on my EI23BC55IS1 3 door refrig, disable the alarm and it makes all ok but happens over and over. Thismorning it was not working other than code CE in the door
Hi Rayna! From what you have described it sounds as if your refrigerator is experiencing an internal communication error (CE). For this particular error code, a professional technician would be required to check the wiring connections between the main control board (brains of your appliance) and the user interface board (control touch pad on the front of your appliance). Once these connections have been checked, the technician will know which component(s) will need to be replaced; if any. Let me know if I can be of any more help. Thanks, Chris
12/27/2013 2:16:16 AM • Electrolux... • Answered on Dec 27, 2013
Electrolux ei26ss55gs6
Good Morning Denise, thank you for allowing me to assist you! If your ice maker has stopped producing ice completely, please check these tips, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also the water shut-off valve or water-inlet valve, or both, may be faulty and if necessary either parts may need replacing. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it after proper diagnoses. Best regards!
11/26/2013 12:49:56 PM • Electrolux... • Answered on Nov 26, 2013
I put in a new ice maker ( the old one broke) and
Make sure the door switch operates the light in the freezer because power is supplied to the im through this switch. Insure the freezer is 15 degrees or lower, these temps need to be reached before the im will cycle. Access the blue tube on the blue valve, disconnect it and blow through it. If you cant blow through it look at the tube that comes from the ceiling to the ice maker and check for ice blocking the tube. If water is coming through the dispenser then the water line that feeds the valve is not frozen and you either have a bad valve or a restricted fill tube.
11/2/2013 1:34:04 AM • Electrolux... • Answered on Nov 02, 2013
My electrolux says power failure, but is working
Hello Kristy, thank you for your post! Let's try reprogramming the refrigerator. This can be done by either flipping the household circuit breaker to the off position or unplugging the unit. It is important to wait roughly ten minutes and then turn the refrigerator on. The error code PF should clear and the unit should resume normal operations. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully.
9/16/2013 5:13:56 PM • Electrolux... • Answered on Sep 16, 2013
Sy ce on fridge door
Hello Debbie Lee - Typically error code SY CE indicates that the refrigerator has detected a communication error at power up. Contact a professional to move forward accurately to check the wiring between main control board and user interface. Depending on the diagnoses, either or will need placing.
2/5/2013 3:34:14 PM • Electrolux... • Answered on Feb 05, 2013
2answers
Electrolux EW28BS71IS ice maker not working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
sfgs
11/17/2012 4:42:01 PM • Electrolux... • Answered on Nov 17, 2012
Electrolux EW28BS71IS (278 cu ft) Bottom Freezer Commercial French Door Refrigerator Logo
Popular Tags
45 questions posted
Top Electrolux Refrigerators Experts
ZJ Limited
ZJ Limited
vince
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Electrolux Refrigerators
Most Popular Question
put in new ice maker old one broke
  • Refrigerators
