20 Most Recent Speed Queen AWN432 Washer Questions & Answers
no
and the lid has to be closed for the machine to start and continue operations
stick with GE
Speed Queen... | Answered on Jul 21, 2017
Oil spots on clothes is from a seal on the drum. The balance issue is from shocks or springs that may be loose or broken and the spin issue is due to transmission. You may have a problem finding parts
Speed Queen... | Answered on Jun 12, 2017
Sorry to say but the water seal between the outer tub and the gearbox has failed and need to be replaced. Not an easy task and should only tackled by an skilled DIY persons. Repair kit and water seals are easily available from the manufacturer. Removing the center nut is a big challenge due to corrosion, soap residue and it requires a special socket.
Speed Queen... | Answered on May 12, 2014
i.think it will not cause problem it depends on how you install your washer just make sure you install it properly..
Speed Queen... | Answered on Mar 08, 2014
it could be the seal and also could be a hole in the tank what about its sound if its normal than it's a hole if you hear strange sound its a seal
Speed Queen... | Answered on Feb 10, 2014
Because the water from the wash is still inside it and has not drained. So you need a new drain pump!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Speed Queen... | Answered on Jan 20, 2014
If there is too much weight to 1 side, sensors in it will stop it from spinning. If you evenly distribute the weight of your clothes this may fix it.
Speed Queen... | Answered on Mar 09, 2013
Speed Queen AWN432 Washer Logo
37 questions posted
Top Speed Queen Washing Machines Experts
Poppa Maddo
Poppa Maddo
Marvin
Marvin
Paul Bade
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Speed Queen Washing Machines
Most Popular Question
oil spots 6 mo old speed queen
  • Washing Machines
