20 Most Recent Quasar SP-3233 TV Questions & Answers
mkbowen,
whats the brand name of your TV?
also try this, facing the front of your screen. locate a button indicating " menu" and click it.
once the menu button been activated there would be a display box indicating "AUDIO" "VIDEO" "TUNNING" or in some cases the screen will indicate one by one setting every time you press the "menu" button. If you'll able to find a display indicating "video" higlight the said icon and navigate throught it until you see the control for brightness. you can navigate the icon by pressing +/- channel button and to change the value of selected item you need to press +/- volume button of the screen.
cheers ,
mark
Quasar SP-3233... | Answered on Mar 25, 2019
Your remote need cleaning. There are improper contacts between the touch pad to internal carbon tracks. You have to open the remote control to do this. Visit this site named 'Electro-help' for details. Check this link, and select the site. It have details about how to clean a remote control. You may also get details about the availability electronic components too, from associated ads. Pull up older posts there.
Quasar SP-3233... | Answered on Jul 15, 2012
There is no user manual to this TV by net.
Quasar SP-3233... | Answered on May 10, 2012
It's probably a write-off. The circuit board inside has been cracked so that some of the copper traces that connect parts have broken. This commonly happens around the area of the horizontal output transformer, which is heavy. The shock of the fall causes the transformer to bounce and breaks the board. Other areas too may have been damaged because of flexing. And worst, the picture tube can be damaged in a fall, so it either doesn't work at all or shows permanently distorted colors.
It's tough to find anyone willing to repair a set that's fallen. Many circuit board tracks are very narrow and hard to repair. Then it's difficult to know if all the damage has been found and repaired, so even if the set starts working a technician doesn't know if something else won't go wrong. And then there's that bad tube possibility; no technician likes to spend lots of time fixing a broken board only to find the set then needs a new tube. Trust me, this has happened to me several times during my career in TV shops.
Your best bet is to use this as an excuse to buy a new LCD or plasma TV. 40-inch models, a good size match for a 32-inch CRT (tube) model, are reasonably priced.
Quasar SP-3233... | Answered on Jul 03, 2011
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers and Driver downloads as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Quasar SP-3233... | Answered on Nov 17, 2010
its more than likley your sensor on your teli. try your menu to see if there is a manual or a remote setting that you can change.
Quasar SP-3233... | Answered on Oct 16, 2010
Size: Width - 70cm/28in; Height - 66cm/26.5in; Depth - 58cm/23in. Weight - 33kg/110lb . With the packing all these dimensions will grow noticeably.
The tube of the tv is fragile so the entire tv must be packed on thick polystyrene sheets (like the ones the tv originally came) and a sturdy cardboard box - packing foam will not do and taped bubble-rap will be bulky it you put enough to do the job.
Quasar SP-3233... | Answered on Jul 13, 2010
Hi mark
To answer your question;
Try to hold the "action" and "power" buttons at the same time for more than 10 secs.
Another one is:If you can get into the menu under "game guard" there might be a lock code , try 333
This works on panasonic tv of the same model, but then quasar is panasonic.
Don`t forget to rate this answer if its helpful
Quasar SP-3233... | Answered on May 19, 2010
If you do not have a remote control for the television, you can purchase a replacement remote which has similar functions and can be used to set / operate the television. You can purchase a replacement remote from here.
Also let us know which functions you are trying to access from the TV menu buttons (like tuning the television, adjusting the picture/sound)
Thanks for using FixYa.
Quasar SP-3233... | Answered on Mar 16, 2010
Look for the action button or key in the front, press once it will give an icon menu, keep pressing the action key until it takes you to the icon you want, use the vol up and dn, channel up and dn to navigate once you are in the sub menu you want. If you need an owners manual click on the following link: http://retrevo.com/s/Panasonic-SP-3233-TVs-review-manual/id/275ag325/t/1-2/. Thank you!
Quasar SP-3233... | Answered on Mar 08, 2010
im a tv expert and we have always these problemes, what you should do is contact your cable or sat provider and tell them your problem and ask if they can reset you acount or code im sure they can help or bring a tv technician and they could fin dout the probleme CONTACT ME AT -mathieugingras@hotmail.com and il see if i can give you more information
Quasar SP-3233... | Answered on Aug 23, 2009
If the screen is dark, then the brightness and contrast adjustment must be poor. Use the MENU key (in the TV or the Remote, either) adjust the brightness and contrast as per your viewing convenience. Service manual for this model is not in my knowledge and you should not try to repair or troubleshoot it by yourself without proper knowledge of the circuit workings inside.
Quasar SP-3233... | Answered on Feb 13, 2009
its nothing really, if your tv is new then it is normal but if it continued to do it then its broken
Quasar SP-3233... | Answered on Oct 15, 2008
if your tv give you that color or keeps fliking your tv screen might be crack or even the tv bolbe is burned get it checked out at a tv store
im sorry but to let you know diamond vision tv is a private tv company that why they are not listed in any universal remote codes because they work for them self and they think that people will stop buying there remotes and so they decide not to programe any codes for other remotes
Hi there!
You can certainly do this yourself. However take care not to break the tube neck when doing so and unplug from mains before you start. All TV'S can be opened by unscrewing the screws around the edge of the frame first. Then on the back panel you should find more screws that holds the AV sockets panel onto the cover. Once all screws had been removed, carefully pull the cover backwards making sure that you don't drop it before the tube neck is completely clear from the cover. Remove the playing cards and reassemble the same way, making sure that all sides are firmly slotted before replacing the screws again. You are correct in quoting "Fire Hazard". It is indeed. Regards and good luck, JUS004
Quasar SP-3233... | Answered on Apr 02, 2008
wont program
Quasar SP-3233... | Answered on Mar 10, 2008
well it's not a wide screen tv show it won't really matter but if it is H/D you will find a red/green/blue connection in the back for picture and red/white for sound
Quasar SP-3233... | Answered on Oct 31, 2007
did you try unpluging it for a while that uaually resets everything
Quasar SP-3233 TV Logo
Popular Tags
23 questions posted
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Quasar Televison & Video
Most Popular Question
32 tv fell over onto carpeted floor
  • Televison & Video
