20 Most Recent
Motorola Mobility CLIQ XT (2 GB) Cell Phone Questions & Answers
How to bypass Motoblur account login screen
When you get to the Motoblur screen press and the 4 square icon until a keyboard appears and type [alt]E[altE] BLUROFF it only works one time and you have to do it each ti,e you see the BLUR sign up page
8/12/2017 10:04:24 PM •
Motorola...
Answered
on Aug 12, 2017
Reset a motorola bp6x
Hi Anonymous
please follow the next steps to make a hard Reset your device : 1. remove the battery cover remove the battery and put it back again
2. press and Hold the R & M key and press and press and hold the power button until you see the android image with the exclamation mark, then release the buttons
3. Press and hold in the middle of the he volume up and volume down key,
4.it will show up a menu then you need to select the 3 option wipe cache and factory Reset selected with the volume down, confirm with the power button, scroll all down until you see the option yes , then press the power where is reboot system now, and that will reset your device.
Regards
Maya
Motorola Support
5/27/2015 8:35:32 PM •
Motorola...
Answered
on May 27, 2015
Motorola screen wont light up
Your phone should be looked at. Have you taken it to your service provider store that also has repair shop inside? They may be able to determine issue.
Mark
Motorola Support
1/27/2015 1:46:27 PM •
Motorola...
Answered
on Jan 27, 2015
How do i delete MyFave on cliq xt
The problem is that even though you've switch your phone to AT&T the t-mobile Visual Voice Mail app is still trying to connect to t-mobile.
You need to: (1) go in to the phone's app settings(2) locate the t-mobile visual voice mail app (3) click on the"Disable" button. This should end the annoying messages.
12/2/2014 3:17:50 PM •
Motorola...
Answered
on Dec 02, 2014
Factory reset
You'll need to enter your Motoblur/motocast ID info or create a new one with a new email address.
6/2/2014 3:18:50 AM •
Motorola...
Answered
on Jun 02, 2014
I need a Subsidy Unlock Code for my Motorola Cliq xt
To get Subsidy Unlock Code for Motorola Cliq XT try http://www.simpleunlocking.com/motorola-cliq-xt/rs16wp9/You can get Subsidy code and step-by-step Instructions to unlock Motorola Cliq XT from there.
12/13/2012 8:39:45 AM •
Motorola...
Answered
on Dec 13, 2012
Phone does not charge beyond 40%.
First Option:mostly nokia chargers doesn't make problems...just try the following..connect ur mobile with a system (usb cable)...found out whether it is charging or not...if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...if it charged with usb cable buy a new chargerPlease change Phone Bettery and check the chargingIF Charging Problem not Solved SoSecond Option:Your Phone charging IC Fault So Please change charging ICAnd charging Problem will Solved Quickly
8/19/2012 3:12:12 AM •
Motorola...
Answered
on Aug 19, 2012
How to unlock my motorola
As far as I know free codes does not unlock your phone, so even if you would find a unlock code or whatever you'd have to spend some money.
I would recommend the
Unlock-Zone.com site is nearly perfect and they were recommended highly in the cell phone forums.
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
8/3/2012 3:49:49 AM •
Motorola...
Answered
on Aug 03, 2012
Need an unlock code for a motorola cliq 2
imei
These directions are for an AT and T phone, but other than that, are the same for any carrier. A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from your phone carrier to unlock your SIM card. You can obtain your phone's PUK code from your carrier in one of these ways: Log in to Your account.online Use a Technical Support Chat Contact your carriers Customer Care Get Your Phone's PUK Code Online Go to the Phone/Device page. From the My Phone/Device screen, select the Unblock SIM Card link under the My Make & Model heading. The Unblock SIM screen will display your PUK code and will give you instructions for unblocking your SIM Card. Once you receive your PUK code, you will need to enter it into your phone to set a new PIN code. Note: If you enter the wrong PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM Card. The phone will display the following error: "PUK blocked call operator
12/2/2011 7:01:33 PM •
Motorola...
Answered
on Dec 02, 2011
My motorola cliq xt shut
Yo! that has got to be a battery problem. i will advice you buy another battery and charge for at least 3hours before first use. thanks
7/29/2011 4:22:09 PM •
Motorola...
Answered
on Jul 29, 2011
