20 Most Recent
HTC DROID ERIS Cell Phone Questions & Answers
Just don't know where to
Hey,
I am sorry but the HTC DROID ERIS is a CDMA phone and not a GSM phone which means that it will not work on any GSM network worldwide. GSM networks use SIM cards whereas CDMA networks do not use sim cards. This phone is a CDMA phone means it works without a sim card and will not have a slot for you sim card.
a list of specifications for theHTC DROID ERIS is available
here
Thank you for using FixYa! Let us know if this answer was helpful to you.
Need manual for HTC Eris
You can download and print the instruction manual in PDF format by clicking this
link.
Adobe PDF Reader is required to view this manual.
Download Adobe ReaderHope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using
FixYa.
How to unlock the htc droid eris without your
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlocking.com which is doing good service .....you can approach this website.
My droid eris will not power on, the screen
Try pulling the battery out for at least 15 seconds and the put it back in and reboot.
If that doesn't work, try resetting it by holding the volume down button and the Send button, then while holding both those buttons, press the End key.
If worse comes to worse, go to the Verizon store and see if they can help.
I have a droid eris
You could try dialing *228 to re-program the phone or pulling the battery out for at least 15 seconds and the put it back in and reboot.
If those options do not work, try resetting it by holding the volume down button and the Send button, then while holding both those buttons, press the End key.
My droid eris is frozen
Eris will not see text
Try dialing *228 and press send. This will program your phone and reset it. Doing this typically fixes sms problems.
When I recieve a text message on my HTC eris droid
1. Press menu button and go to sound and make sure it's not in silent mode and that you've got an actual audible notification selected.
2. Launch you messaging application and check your settings there as well and make sure you have notifications enabled.
How to replace a cracked screen
its a very tough task please dont try it with ur hand coz....it affect ur cell n u may b fail go to any shop they will charge u 80/- only n set it right
Unlock Eris from Verizon so that I can use it with
You cannot do this. Straight Talk only allows phones with specific MEIDs on their network. You could use your Eris with PagePlus, another prepaid provider that uses the Verizon network. They have a 1200 minute/2000 text/100MB plan for $29.95/month.
Can my htc droid eris from verizon work on
If you go here: http://b2b.vzw.com/international/Roaming/Asia-Pacific/India.html#network you can see that Verizon does have roaming agreements with CDMA providers throughout most of India, so I think your phone will work just fine.
Before you go, you need to dial *611 from your phone and have them activate International Roaming on your account. The rates are available on the link above, and they are quite expensive, so be aware of that before you go.
You should probably also disable Data Roaming on your phone before you go to avoid a massive bill, international data is extremely expensive.
