20 Most Recent Quasar SP-3235 32" TV Questions & Answers
Have Sony Trinitron model KV-32HS420, serial #
These tv's are being given away free, or left at the curb. Go to a used site and check the free section, there will be tons just waiting for you to move it for them. As for printers, good luck they make the money on the ink, go to an aftermarket ink refiller.
2/27/2017 11:37:50 AM • Quasar SP-3235... • Answered on Feb 27, 2017
Adjust the horizontal width on a sp-3235
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Alighment procedure to many popular brand TVs are given.
12/25/2016 12:43:59 PM • Quasar SP-3235... • Answered on Dec 25, 2016
How do I find out if, my Quasar 32 inch LEDTV is still under warranty?
If it is over 1 year old it is not under warranty.
9/8/2016 9:12:31 PM • Quasar SP-3235... • Answered on Sep 08, 2016
I need the code list for a Quasar big screen tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
10/18/2015 1:49:42 AM • Quasar SP-3235... • Answered on Oct 18, 2015
What is the password for the TV?
0000,1919. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box. http://electronicshelponline.blogspot.com/ http://remotesearch.blogspot.com/ http://electro-medical.blogspot.com/ http://electrohelponline.blogspot.com/
5/24/2015 5:47:57 PM • Quasar SP-3235... • Answered on May 24, 2015
Quasar tv yes
Yes.
10/24/2013 8:45:53 AM • Quasar SP-3235... • Answered on Oct 24, 2013
manual
Secondary picture
YOU HAVE PUSHED THE BUTTUN FOR pip ( PICTURE IN PICTURE ) YOU NEED TO PUSH IT AGAIN TO SWITCH IT OFF
6/28/2013 11:46:30 AM • Quasar SP-3235... • Answered on Jun 28, 2013
I own a Quasar SP-3235 32" TV. It has a slight green tint after 10 years of use. How can I adjust the color screens on this set? Is it a function of the remote like Sony TVs or do I need to remove
I would open it first and look, a lot of those had both the screen and drive controls on the PCB at the end of the picture tube, at least look there first.You are dead on in looking for the screen controls, if you find one it should only be a tiny adjustment due to age and the Crt changing a bit.
12/13/2012 4:31:45 PM • Quasar SP-3235... • Answered on Dec 13, 2012
How can i unlock tv with no remote
Infra Red LIGHT OUT My original remote control stopped working, so I purchased a universal remote and went through
11/27/2012 9:39:37 AM • Quasar SP-3235... • Answered on Nov 27, 2012
Need manual for Quasar TV model SP3233B made 2000
  • Hi, I can help.
  • When you get to the link click on"Click here to start download from MediaFire.." and tha manual will download onto your computer.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
10/30/2011 11:02:12 AM • Quasar SP-3235... • Answered on Oct 30, 2011
Quasar VV-1301 cant program for cable
Ur tv have a manual Menu button on the front of the tv bazel frame?Yes used that manually Menu button pushes go into the tv menu to find select CABLE do autosearches by hand through a manually selected by functions buttons like channels buttons up and down as selections and menu button as enter to excicute functions.No try website like Remotes.com to buy the tv original remote to used.
8/18/2011 6:44:06 PM • Quasar SP-3235... • Answered on Aug 18, 2011
My son might have been
Hello
Enter into its "Menu" and srf through, come to "Audio" window. There you can see Audio Adj, Other adj, surround, speakers. Check the speaker status. Hilight the option "Speakers" If it is turned OFF make it ON. OK.
7/2/2011 4:22:38 PM • Quasar SP-3235... • Answered on Jul 02, 2011
Tv got a straight horizontal line
Hello
A straight horizontal line across the center of the screen denotes the full failure of vartical sweep in your tv. There is two main reasons for this. The first one is vertical output Ic and any of its related parts inside the printed circuit board of your tv is faulty. The second one is deflection yoke [the coil fitted alongwith at the neck of the picture tube] is open. The second fault said here is very rare. The fist one is reported more.
There may be, as said earlier, the IC [Integrated Circuit], may be faulty. You just locate the vertical output Ic inside your TV. normally in most televisions, it will be screwed into a heatsink metal, as it will be get heated during operation, the metal conducts the heat gereated by this Ic to the surroundings, to make it at a constant safe temperature. In most cases, we have seen, this Ic may opend. That is its inside drive integrations got faulty. It has a particular number marked on it. You must note that number and replace it with a similar type and number.
You just open the back cover of your tv, while it has been isolated from the mains supply, by unpluging it from the wall socket. There are four wires run to the deflection yoke (stated earlier), amoung, two of them will be thicker than the other two. Catch up the other two thinner wires, and look from where it is connected to the main board. You can see very near to this connection, an Ic fitted into a heat sink screwed. That is the Ic in suspect.
With set open, supply it and wait for 5 minutes or so, and unplug the tv from wall socket, and touch the heatsink of that ic gently, and see whether it overheats or not. Some amount of heat will be there, but it should not be overheated. If overheat is there, the Ic has damaged. Replacing it is the only remedy.
Another possibility is, the said Ic doesn't get the proper supply voltage to it to work. To find this, you should have a multimeter in hand, and the ability to find out the points I am going to report. Refer to the schematic diagram of your TV [not the manual, It gan be get from electronic book shops], and find out the main supply point of that Ic. It is a hot check, that is you only can check it with your tvs printed circut board pulled out, and the tv is switched on. Every precaution against electric shock shuld be taken before that. Keep children away from you, and let an adult beside you.
If the main supply voltage is correct, it may be around 35VDC or so, check the voltage of its output pin. It should be neare to 1/2 of the main voltage. If ther is exess votage shown, or no voltage at all, surely the said Ic is faulty. Replacing it will solve the problem.
Find any difficulty, report it to Fixya. They will give alert yo me. Ok.
10/21/2010 11:36:28 AM • Quasar SP-3235... • Answered on Oct 21, 2010
I have a Celera K12B-C11,
I have a celera tv and when I turn it on it has a symbol of a key in the bottom corner. It will not do anything. How do I unlock it?
9/7/2010 7:41:14 PM • Quasar SP-3235... • Answered on Sep 07, 2010
I cannot get chk 0eac2
manual
  • http://dl.owneriq.net/a/ace0fc7a-fac7-4265-9377-c46a5c94afa8.pdf
remote I really suggest a universal (le$$), but here is the original
  • http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12824494394700&smodel=SP3235&brand_pn=QUASAR_SP3235
8/22/2010 4:02:59 AM • Quasar SP-3235... • Answered on Aug 22, 2010
I have a Quasar TV that has worked perfectly fine
Check all your channels. If you are getting sound on some channels but not others it is a good possibility that your SAP setting is turned on. Simply go into your audio menu and disable the SAP. Not sure about your model tv but some Tv sets had a switch on the back to disable the speakers and some have a setting in the menu to disable the speakers. If you have a digital cable box hooked to the tv it is possible the cable box volume is turned all the way down which will override your tv volume. Check these options and hopefully one of them works for you.
7/10/2010 3:53:15 AM • Quasar SP-3235... • Answered on Jul 10, 2010
Quasar SP-3235 32" TV Logo
79 questions posted
Top Quasar Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Quasar Televison & Video
Most Popular Question
own quasar sp 3235 32 tv slight green
  • Televison & Video
