20 Most Recent Quasar VHQ400 VHS VCR Questions & Answers
Timer light stays flashing all the time how do i get it to go out?
You need to go in the on screen menu and set your clock. This will stop the flashing.
8/30/2014 4:50:33 PM • Quasar VHQ400... • Answered on Aug 30, 2014
Toshiba vcr operates for a few seconds then shuts down
When a VCR encounters a problem with the drive mechanism the unit will shut itself off to prevent further damage. You should take the top cover off and look around at the mechanical section for damage. If you can't see anything, leaving the top off, insert a video and watch what happens to it. This will give you a clue to the problem.
12/27/2013 1:00:17 AM • Quasar VHQ400... • Answered on Dec 27, 2013
Can I buy a remote from you, the universal doesnt
Let me buy a Goldstar Vhs & Dvd player combo remote control from you.
9/22/2013 11:55:11 PM • Quasar VHQ400... • Answered on Sep 22, 2013
I cant program my quasar vcr to record
the processor has some garbage in it do to a small power surge and if you unplug the unit from the wall for 40Min, it will reset back to normal.
11/26/2011 9:32:34 PM • Quasar VHQ400... • Answered on Nov 26, 2011
I do not have the
EWhat ever you are watching through your VCR at the time and to put a tape in and hit the record button.
7/13/2011 4:26:07 PM • Quasar VHQ400... • Answered on Jul 13, 2011
The litle green light blinks
Tries the unit unplug,replug it back like about an hour.The unit should be resetting itself.Now the green power light should be stable again now vcr should be work again,still blinking green power light mean the unit have power circuitries issues,not worth trying to fixed the unit.Because VCR devices are pretty cheap these day,can buy a new one like $40 bucks.
6/18/2011 9:59:51 PM • Quasar VHQ400... • Answered on Jun 18, 2011
Im looking for a manual for my video recorder
Click HERE to download required user manual of Panasonic VHQ-41M
Thanks.
6/10/2010 8:44:30 PM • Quasar VHQ400... • Answered on Jun 10, 2010
I have a new vhs dvd player recorder that will not...
please note in your vhs dvd manual it tells which dvd (maxell, tdk etc.)are compatible with the recorder
okay do you have a cable/satellite box connected to tv/monitor? yes or no
yes- is the the tv on ch 3? cable connected to cable box in, cable box out connected to dvd in,(on dvd set up menu make sure broadcast is cable) dvd out connect to tv... ? please note some dvd recorder will not record HBO (you can record on vhs tape)
no connect antenna to dvd in, dvd out goes to tv.....
hope this help...
5/24/2010 4:42:13 AM • Quasar VHQ400... • Answered on May 24, 2010
Video head need cleaning is it wet or dry
The best way to clean a video head is to remove the top outer cover, then you can spray the head with Servisol Video 40. You can also spray the audio/control head at the same time. You can get Servisol from electrical shops and also online (image below).
5/11/2010 3:16:31 PM • Quasar VHQ400... • Answered on May 11, 2010
The best way to clean a video head is to remove the top cover and Spray the heads (both video head and audio/control heads) with Servisol Video 40 see image below. Just let it dry up (which wont take long) and that should do the trick. If you spot some nasty bits of dirt, spray a cotton bud and wipe it away.
3/17/2010 7:35:30 PM • Quasar VHQ400... • Answered on Mar 17, 2010
When I go to program my recorder it comes up with
Unplug your unit for about 1 minute, then plug it back in again (resets the unit). Select English as the language, and you're set. Good luck to you!
12/13/2009 5:42:52 AM • Quasar VHQ400... • Answered on Dec 13, 2009
2answers
How do I unlock the child lock mode on a Quasar
Quote:
... The VCR was purchased at a consignment shop and there was no remote or manual with it.
Check here for the Quasar-VHQ400-VRC-User-Guide (page 26 for Reset All VCR Memory Functions).
Hope helped. Good luck.
10/23/2009 4:36:44 AM • Quasar VHQ400... • Answered on Oct 23, 2009
2answers
Who makes Quasar? Is it an RCA product?
Panasonic
10/15/2009 8:43:30 PM • Quasar VHQ400... • Answered on Oct 15, 2009
Vcr showing "no signal check aerial"
Retune your video channels
9/16/2009 8:52:58 PM • Quasar VHQ400... • Answered on Sep 16, 2009
Have digital TV have 3 yr old sony VHS VCR DVD player combo
A DTV converter box will take digital broadcast signals from the antenna and convert them to a format compatible with the VCR. You will be able to record programs received through the DTV box on your VCR if you could record analog over-the-air programs before the digital changeover. You can use either the RF output or the component output from the DTV box to input to the VCR.
6/30/2009 11:31:45 PM • Quasar VHQ400... • Answered on Jun 30, 2009
Quazar Model VHQ520/VHQ540 cannot record after inst Digital Conv
You need to set the vcr to channel 3 or 4 (whatever channel the digital converter box is set to broadcast on) to record a program. The digital converter box has to be set to the channel you want to record the show from.
6/2/2009 1:47:56 AM • Quasar VHQ400... • Answered on Jun 02, 2009
Clock
most of these use the remote control to set clocks. Find the menu button and scroll through all options...it should be there.
2/14/2009 12:30:22 AM • Quasar VHQ400... • Answered on Feb 14, 2009
My vcr won't play.
Sounds like a bad belt or the tape isnt loading into case correcly bad rubber idler assy.
10/24/2008 3:18:07 PM • Quasar VHQ400... • Answered on Oct 24, 2008
Quasar VHQ400 VHS VCR Logo
Popular Tags
33 questions posted
Top Quasar Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Quasar Televison & Video
Most Popular Question
im looking manual video recorder
  • Televison & Video
