20 Most Recent
Crown XTi 6000 2Channel Amplifier Questions & Answers
Schematic diagram
Cannot give you the diagram but repaired some of them. whats the problem?
Crown xti 6000 cuts on
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
Thank you for using Fixya
Power Crown XTi 6000 activates protection and does not generate PWM what could it be?
The Power Crown XTi 6000 is a power amplifier, and it sounds like it is activating its protection circuit and not generating a Pulse Width Modulation (PWM) signal. There could be a few different reasons for this behavior. Some possible causes include:
- Overheating: The amplifier could be overheating, causing the protection circuit to activate in order to prevent damage.
- Short circuit: There could be a short circuit in the amplifier, causing the protection circuit to activate.
- Input signal issue: The input signal to the amplifier could be causing the protection circuit to activate. This could be due to a problem with the source, such as a malfunctioning mixer or a disconnected cable.
- Output impedance or load mismatch: The amplifier may have a mismatch in output impedance or the load impedance which can cause the protection circuit to activate.
- Firmware or software issue : There could be a problem with the firmware or software that controls the amplifier, causing the protection circuit to activate.
Without more information, it's difficult to say for certain what the problem is. It's recommended to check the manual for troubleshooting steps and also check for any possible firmware updates. If problem persist it's recommended to take professional help.
Crown CDi 1000 amp thermal on
Google should have a manual for your 1000 amp thermal and also try on the companies official website too for a manual. Try searching on YouTube as well and YouTube should have videos about amp thermal on - Crown Audio Players & Recorders
Did you receive my DVD of THe Crown Series one?
Hello, Sylvia -
I have no idea what entity you meant to receive your question.
You posted in the Fixya.com website, which is intended for asking and answering questions on how to go about REPAIRING THINGS. Plus, your question landed in the Fixya category for Crown (brand) Audio Players & Recorders.
Perhaps you meant to message Netflix, or your local public library, or a person from whom you borrowed the DVD, or someone to whom you sold the DVD, or . . .
Best wishes.
