20 Most Recent
Sony KDL60EX700 60 in. TV Questions & Answers
Sony kdl 60ex700 red led blinks 3 times
Hi
3 Times Blinking is for the following reason
DC_ALERT -------> DC_ALERT
DTT_WDT --------> DTT Error
AUD_PROT -------> Audio Abnormal Detection
Kind regards.
Rehan
Sony blinks 7 times
Hi
7 Times Blinking is for below reason
TEMP_ERR Thermal Error
FAN_ERR FAN Error (Not Detected. Display Only)
Kind regards
Rehan
Blinks red 7 times
Check your owners manual for troubleshooting guide first. It could be something as simple as bad batteries in the remote.
My sony tv shuts off after 30 sec or so and blinks 4 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
TV powers on and goes black.
first i'd say try all the normal things...
swap sources, check to see if the osd comes up, etcetera. it might just be that the tv isnt receiving a signal from the source its tuned to. see if theres a way to factory reset the tv, try it.
if no matter what you do nothing shows up...
maybe the backlight burned out or maybe something on the mb burned out. go over and sniff the tv, notice any smell? if this is the case, i dont suggest trying to fix it new screen.
Hdmi input not working composite
The most likely solution to your problem is to go into the tv's settings and verify that the input (which ever the the number is) is not set to "skip" as that will make it appear as if it doesn't work. Just change the label for that input to anything but "Skip".
Good Luck!
Rich Lilja
Good Luck! I hope this helps.
Rich Lilja
Standby light blinking
-Check your Manual look for something called blinking codes should be around page 9.-Please tell me you have a warranty, if not this can be expensive. Ranging from the main control board.- Have you tried cleaning bot ends of your LVDS Cables, this can sometimes remedy the problem.
