20 Most Recent
Samsung PN42C450 42 in. TV Questions & Answers
Loud buzzing sound from tv with no picture
It sounds as though your SMPS is seriously faulty and normally one can buy a kit to correct the problem if you are a TV engineer, however there could also be many other reason for the condition that you describe its almost impossible to guess correctly, it really needs a qualified engineer to assess the problem along with he or she having the set with them.
Remote code pn
follower the instruction in the remote booklet for auto search
Samsung PN42C450
I don't deal with plasma's all that much, but usually on the right side of the TV is the Y Sustain board. It is possible that you have a short on the board.
My Samsung 42 inch plasma TV is cracked, do you
all you can do is
Google the make and model of your TV followed by Replacement screen
you will only get it off the internet, no local shop or supplier will have one
If your tv is under warranty get it repaired / replaced
otherwise you can do it yourself
its relatively simple to do
Is the any problem in samsung plasma panel i have
I looked it up and hjave not found any dissparaging comments on this TV yet. I have a 32" and love it. Just type youmodel and brand in the search bar on your computer and look at ratings and comments.
Samsung plasma TV PN63A650 will not turn on, just makes continuous clicking.
the capacitors seem to have gone bad if they have like a black dot on them it is a sign they have actually blown they can be replaced by placing new ones on but it would be better if the board was replaced (unless you wish to replace those capacitors please please do be careful in doing so they hold enough charge to give you a bad zap even kill if one isnt careful)
Samsung 60 inch plasma not turning on. Unplug HDMI and turns on. Let it warm up (15min) then one HDI (720) works. Replaced caps but no change.
Fault at its main digital board.
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. ..
