20 Most Recent Samsung LN55C650 TV Questions & Answers
Hi I have a Samsung LN55C650.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
7/17/2017 3:29:52 PM • Samsung LN55C650... • Answered on Jul 17, 2017
What is the remote code to access the service menu on a Sansung ln55c650?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done. NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
1/1/2016 12:10:29 PM • Samsung LN55C650... • Answered on Jan 01, 2016
The backlight on my Samsung ln55c650 goes out after being on for a short time.
11/20/2015 2:36:45 AM • Samsung LN55C650... • Answered on Nov 20, 2015
Samsung LN55C650 picture is dim on the right side
Hi, this sound like the same fault as i had, our tv only had half the screen go off also, the right side, after looking up on the internet i found a video for a fix, what you need to do is remove the back cover, there will be ribbons that go from the front screen to the main panel, i removed each one at a time and rubbed the contacts of the ribbon with a rubber on the end of a pencil, plugged them all back in and switched it on and it was now spot on, thats more than a year ago and its still working spot on, hope this helps jim
3/1/2015 10:34:20 PM • Samsung LN55C650... • Answered on Mar 01, 2015
2answers
Problem with Samsung UE46D6100SKXXU. Screen starts to flicker then gets a shadow/double image then alternates between flicker and double image. But this only starts when the TV has been on for about a
You can adjust this. The procedure is called flicker adjustment. But, you have to enter its service mode to do this. To get more details, http://electronicshelponline.blogspot.com/ Pull up older posts.
11/25/2014 9:35:17 PM • Samsung LN55C650... • Answered on Nov 25, 2014
Red vertical lines samsung
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD screen is given with illustrations.
7/29/2014 3:53:38 AM • Samsung LN55C650... • Answered on Jul 29, 2014
0answers
0answers
0answers
Intermittent change of resolution.
Sounds like nothing more than a tcon cable connection. I would try unplugging then plugging the cable connection to the tcon and also the two upper tcon cables that are located under the Tcons metal cover.
12/16/2012 6:09:31 PM • Samsung LN55C650... • Answered on Dec 16, 2012
3answers
New device not found/ usb2
I called 1-800 SAMSUNG and they had a firmware update that fixed the problem. I don't know if the update is available on their website, as I had downloaded a firmware update 2 days previous and this was a newer version that they sent me via email.
11/14/2012 2:57:41 AM • Samsung LN55C650... • Answered on Nov 14, 2012
Samsung LN55C650 shut down; won't come back on again!
Someone has to open the set and look first at the power supply--if you are not able to do that consider having a shop look at the set.
6/11/2012 5:47:45 PM • Samsung LN55C650... • Answered on Jun 11, 2012
We have a samsung plasma 50 inch 3DTV. Its
hi ... can i know why you did not accept the solution?
3/29/2012 3:30:11 AM • Samsung LN55C650... • Answered on Mar 29, 2012
3answers
Screen has started to flicker constantly. tv is
I had the same issue occur on my ln55c650 and they had to replace the power supply pc-board. Seems some issue with power module in the TV rather than the side panels. Luckily for me, TV was still in warranty.
12/2/2011 3:37:06 PM • Samsung LN55C650... • Answered on Dec 02, 2011
Ln55c650 flashe s
The Problem is with the power supply. It needs to be replaced. It is having abiasing problem that causes the backlight to flicker or strobe
12/2/2011 3:34:38 PM • Samsung LN55C650... • Answered on Dec 02, 2011
Samsung LN55C650 TV Logo
37 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
LN Samsung
  • LN Samsung
Most Popular Question
backlight samsung ln55c650 goes out
  • Televison & Video
