20 Most Recent
Samsung UN55C7000 55 in. TV Questions & Answers
Red blinking power
I had the same problem with my 55 inch Samsung TV (blinking red standby light and a clicking sound when the TV was turned on, TV would not come on). After checking components on the power supply board I found that the five 33 ohm (orange-orange-black) resistors and changed value. Each resistor measured approximately 3.6 ohms.
I replaced all five resistors. Now the TV works.
10/27/2018 7:45:12 PM •
Samsung...
Answered
on Oct 27, 2018
My Samsung UN55c7000 does not
I'm sorry for the difficulties you're experiencing as the HDMI port on the TV is not working as expected. Please follow the below troubleshooting steps and check the operation.
- Please make sure that the connections are secure and proper.
- Unplug the TV from wall outlet for more than 5 minutes to perform a power resetting and check the operation.
- Check whether the HDMI input is skipped.
- Please connect a different device to the same port on the TV and check the operation.
Thanks for understanding. Please let me know the result after performing the steps.
5/1/2014 5:21:28 PM •
Samsung...
Answered
on May 01, 2014
When I try to watch
Hi,problem solved.. First you will need to open the back of the TV and locate the dry joint area inside the TV, You will need to locate where Some IC at the dry joint area.
In there, they are capacitors that are la belled Vertical lines on the panel(any IC written to vertical)...
When you locate the IC, You will need to re-solder the Capacitor. But before doing that,you can test if the capacitor is still working properly by tamping and the bottom of the IC. If the bottom of the IC has a swollen end, that means IC is GOOD,But it the bottomof the IC is flat,That means IC is BAD, Needs to be replaced...
After soldering if the problem still occurs,That means a capacitor or a resistor around the vertical line area is BAD and will need to be replaced..
After doing that,wa! la!, Your done..
Please make sure you power off the TV before attempting this instruction to avoid the risk of shock...
And also if you think you can not be able to fix it your self, please contact and expert for help...Thanks..
4/15/2011 4:15:12 PM •
Samsung...
Answered
on Apr 15, 2011
Sound but no picture
This Samsung UN55C7000 should be under warranty! Or you are not asking about this model? No pictures on ALL inputs?
Please clarify.
1/14/2011 5:26:51 AM •
Samsung...
Answered
on Jan 14, 2011
Is it multi-volt? 110-220 power?
Hello tony, Mostly all LCD tvs are autovolt, you can find the specs at the back. coming from Samsung, its Autovolt already.
10/27/2010 8:53:11 AM •
Samsung...
Answered
on Oct 27, 2010
Samsung 5 blink code
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
10/27/2017 12:21:54 PM •
Samsung UN...
Answered
on Oct 27, 2017
Samsung LCD TV UN55C7000WF will not turn on
Fault at its main digital board.
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
