1. Select the Settings icon
2. Select General
3. Go to the bottom and select Reset
4. select Reset All Settings (Warning! This will reset everything on the General page)
you can, try pairing your headset with a friends phone just to makesure it works at all. Also, it doesn’t matter if the WiFi is on or offwith the iPhone,they use two different frequencies.
also ensure if u ve tried this
Turn on your Bluetooth headset.
From the Apple menu, select System Preferences.
Click the Bluetooth icon. Click the Devices tab.
Select your Bluetooth headset (it should be displayed in Bluetoothdevices; give that a moment to show up and name itself properly).
Click the "Set Up New Device" button.
Follow the Bluetooth setup assistant instructions for your headset.
- Select "headset" when the assistant asks what type of device.
- Have the manual for your Bluetooth headset handy. At some point,you will need to enter the passkey for your headset into the Bluetoothsetup assistant.
and also
Click the Settings tab.
Check the Discoverable checkbox and the "Show Bluetooth status inthe menu bar" checkbox. (Later, you can turn Bluetooth on by going tothe Bluetooth status in the menu bar.)
Click the "Turn Bluetooth On" button.
Close System Preferences.
if both the above methods doesnt work....
Download, install, and run the Apple Bluetooth Firmware Updater.
- Download the Apple Bluetooth Firmware Updater, version 2
- Double-click the BluetoothFWUpdate1.2.dmg file that you justdownloaded. A Finder window for Bluetooth Firmware Updater 1.2 opens.
- In the Finder window, double-click theBluetoothFirmwareUpdate1.2.pkg file. The updater will install into theApplications > Utilities folder.
- Follow the install instructions for the Apple Bluetooth Module Firmware Update.
- Go to your Applications > Utilities folder. Run Bluetooth Firmware Updater.app.Warning! If you're using a D-Link DBT-120 USB adapter,this will make it Macintosh only! If you used your D-Link DBT-120 USBadapter with a Windows computer, you will no longer be able to do soafter this step.
if all the above method methods fail and if u tested ur voyager and found it works on another mac.... its time to call apple......
good luck
thank you for using fixya...
have a nice day.....
