20 Most Recent Kyocera Mita KM-2050 Printer Questions & Answers
I have a Kyocera KM-2050 machine with problems. I have an ink dirty line on the reverse side. Please guide me how can I remove and clean it. While I have also added new ink.
Question edited for clarity. Question moved to model category. Instructions for cleaning the paper feed path and the developer. https://www.google.com/search?q=kyocera+km-2050+clean+paper+feed ..
10/22/2023 4:38:53 PM • Kyocera Mita... • Answered on Oct 22, 2023
My computer can not see my km 2050 printer
The software will only work on Vista! Time for a new printer.
4/22/2021 11:41:44 AM • Kyocera Mita... • Answered on Apr 22, 2021
How can I remove print mode error?
Doesn't like your paper size? https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk00L4-91KewA3vebAYh7Dj9eIe5b7A%3A1610830848662&ei=AFQDYMLlJ4uz5NoP-YqVwAc&q=kyocera+print+mode+error Google make model manual look at the troubleshooting section or use CTRL+F and type 'print mode error', press enter. ..
1/16/2021 9:03:10 PM • Kyocera Mita... • Answered on Jan 16, 2021
Reset all originals in DP
reseat orignals on DP.
3/2/2020 2:57:17 PM • Kyocera Mita... • Answered on Mar 02, 2020
2answers
How to reset all originals in DP Kyocera km 2050
It just means take all the pages out of the document feeder on top and put the whole complete document in again
10/30/2019 10:43:43 AM • Kyocera Mita... • Answered on Oct 30, 2019
2answers
How to connect km 2050 machine to pc through cable
What cable usb or network cable
12/29/2018 9:44:22 AM • Kyocera Mita... • Answered on Dec 29, 2018
Kyocera mita km-2050 copier printer give error
your error is : C210 Paper conveying motor check paper motor remove and check clean with alcohol and than oil it
12/8/2018 3:18:55 PM • Kyocera Mita... • Answered on Dec 08, 2018
Kyocera km2050 is displaying message "program
need firmware update. will have to be done by factory tech
7/20/2018 1:25:55 PM • Kyocera Mita... • Answered on Jul 20, 2018
2answers
KM-2050 / error c3100
C3100 Scanner carriage problem
• The home position is not correct
when the power is turned on or copying
the document placed on the contact
glass. Poor contact of
the connector terminals.
Defective scanner
home position
switch.
Defective engine
PCB.
Defective scanner
motor.
7/12/2018 2:24:09 PM • Kyocera Mita... • Answered on Jul 12, 2018
Kyocera mita km2050 kx printer shows print error and does not print?
MR KIRAN now which type of error is that the machine showing alert mi soon you will get immediate answer thanks
5/12/2018 12:26:52 PM • Kyocera Mita... • Answered on May 12, 2018
HOW I CAN FIX THE ERROR CODE C6400
heater problem press10871087 after press 163 reast
3/23/2018 9:20:00 AM • Kyocera Mita... • Answered on Mar 23, 2018
0answers
Reset KM-2050
Be the first to answer 1/25/2018 10:18:02 AM • Kyocera Mita... • Posted on Jan 25, 2018Be the first to answer
Error code in 3045 km kyocera
Zero-cross signal error While fuser heater ON/OFF control is performed, the zero-cross signal is not input within 3 s. fuser related problem
12/11/2017 10:20:12 AM • Kyocera Mita... • Answered on Dec 11, 2017
Call for service c4000
Polygon motor synchronization problem The polygon motor does not reach the stable speed within 20 s of the START signal turning on. Poor contact in the connector terminals. Check the connection of connector YC3 on the engine PWB and laser scanner unit, and the continuity across the connector terminals. Repair or replace if necessary. Defective polygon motor. Replace the laser scanner unit. Defective engine PWB. Replace the engine PWB and check for correct operation.
12/11/2017 9:53:23 AM • Kyocera Mita... • Answered on Dec 11, 2017
Error code C6400
check your fuser unit thermistor or thermostat or lamp as the following digita 1087 1087 and put 163
9/8/2016 5:19:14 AM • Kyocera Mita... • Answered on Sep 08, 2016
I want to know my ip address of my printer mita km -2050
193.165.1.13
9/1/2016 11:34:01 AM • Kyocera Mita... • Answered on Sep 01, 2016
Kyocera Mita KM-2050 Printer Logo
193 questions posted
Top Kyocera Mita Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Ngoro
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Kyocera Mita Office Equipment & Supplies
Most Popular Question
lost pin code kyocera 2050
  • Office Equipment & Supplies
