20 Most Recent Cellular Innovations HFBLUH1 Bluetooth Headset Questions & Answers
2answers
Cannot 'pair' the HPBLU H1
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
11/26/2016 3:25:30 AM • Cellular... • Answered on Nov 26, 2016
0answers
0answers
Use on pc
Be the first to answer 10/15/2013 12:03:56 AM • Cellular... • Posted on Oct 15, 2013Be the first to answer
0answers
Manual
Be the first to answer 6/13/2013 4:39:50 PM • Cellular... • Posted on Jun 13, 2013Be the first to answer
0answers
I recently bought a HFBLU-H1
Press and hold the power button for at least 5 seconds and the light should start flashing. This indicates it is now on.To set it up for syncing, with the unit off, press and hold the power button until the light is on and steady, not flashing, it is now is in sync mode. After you sync the unit it will return to normal operation. Let me know if I can help you can further.
8/20/2011 6:17:30 PM • Cellular... • Answered on Aug 20, 2011
Cant remember how to pair my HFBLUH1 to my phone
Hold down the button on the headset until it turns on and keep holding until it starts flashing blue and red. At that point the headset is ready to pair. Go to your phone and scan for devices. If you are asked for a password, try either 0000 or 1234.
2/28/2011 8:21:06 PM • Cellular... • Answered on Feb 28, 2011
I lost my pass code for my cellular innovations
passcodes for bluetooths are almost always either "0000" or "1234"
8/13/2019 9:19:46 PM • Cellular... • Answered on Aug 13, 2019
I found an old bluetooth headset and charger but no instructions so m wondering how do i pair a cellular innovations headset hfblu-fp1 to my phone
you'll have to find out which button triggers the pairing mode. it'll either be the power button itself or the answer call button. hold either one for a few seconds till the light continuously blinks or is static (depending on model) then it'll show up on your phone.
2/22/2016 1:15:42 PM • Cellular... • Answered on Feb 22, 2016
0answers
: MI-EMSB1
Be the first to answer 6/27/2014 3:52:34 AM • Cellular... • Posted on Jun 27, 2014Be the first to answer
0answers
0answers
0answers
Cellular Innovations HFBLUH1 Bluetooth Headset Logo
Popular Tags
21 questions posted
Top Cellular Innovations Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Cellular Innovations Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Cellular Innovations Radio Communications
Most Popular Question
recently bought hfblu h1
  • Radio Communications
