20 Most Recent Cellular Innovations HFBLU10K Bluetooth Headset Questions & Answers
passcodes for bluetooths are almost always either "0000" or "1234"
Cellular... | Answered on Aug 13, 2019
you'll have to find out which button triggers the pairing mode. it'll either be the power button itself or the answer call button. hold either one for a few seconds till the light continuously blinks or is static (depending on model) then it'll show up on your phone.
Cellular... | Answered on Feb 22, 2016
Call Cellular Innovations direct and they will e-mail you a manual. Call toll free 1-800-266-4026.
Cellular... | Answered on Sep 27, 2009
guessing here but check the left/right balance pot is working properly and that the left side is not disconnected
if no one else answer , it will be off to a repair shop for a proper diagnosis and quote
Radio... | Answered 3 days ago
If you're referring to the 200bt portable speaker set, this isnt possible. Car stereos are only designed for input over bluetooth not output. Now if it really important to you, you can use a line level adapter to tap into the rear speakers of your vehicle, take that output and plug it into your speakers with an aux cord, or if you have an after market radio you can use RCA cables and a jack adapter to do the same. If you must bluetooth (eg. out of vehicle operation of speakers) buy a cheap bluetooth output adapter (shark makes one) use a small cigarette lighter inverter to power it, and then you can plug your aux jack into it and bluetooth to a speaker set outside of the car. If you use this in conjunction with the speakers car there will be a delay between those speakers and your bluetooth speakers.
Make sure that the pair on your output device states paired for phone and music. It can still pair for phone and data but not pair to stream music. This is common on android devices especially. If this be the case, unpair the device and forget (delete) the earbuds on your output device. Ensure any bluetooth devices like amazon Alexa, TVs and other common things are powered down. Turn the bluetooth on the output device off, then back on. Search for earbuds and follow manufacturer procedures to sync earbuds. Once found, pair. Ensure when a successful pair happens that they are paired for phone and music. It will tell you on the output device if the pair was successful for both. At this point make sure your volume settings are not muted or all the way down and you should be enjoying music if you have an app playing music.
You likely tripped a fuse or circuit breaker. If you are referring to an automotive type stereo there will be 2 fuses associated with this problem. One is directly on the back of the head unit and is usually 10amp, the other is in your vehicle fuse box usually labeled radio in the diagram.
I am guessing the CB has a fault and needs taking to a CB Doctor...
Radio... | Answered on Feb 15, 2020
Correct, they are smoked and cured with salts and are partially dried out. Simmer in stock for a a few hours until tender. Keep the stock to make pea and ham soup.
Masterchef Andrew
Radio... | Answered on Feb 13, 2020
try putting in your make an model then search google for (your item+mk+model+pinout?) like this. *shruggs* mite get lucky
Radio... | Answered on Feb 10, 2020
Cellular Innovations HFBLU10K Bluetooth Headset Logo
8 questions posted
Top Cellular Innovations Radio Communications Experts
Anthony Ward
Anthony Ward
Marvin
Marvin
Are you a Cellular Innovations Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Cellular Innovations Radio Communications
Most Popular Question
recently bought hfblu h1
  • Radio Communications
