20 Most Recent
La Crosse Atomic Projection Alarm Clock In Temp Wt5110 Questions & Answers
I need a manual to reset the projection.
Hello
I've the manual you need; for La Crosse WT5110 radio controlled projection alrarm clock. But I can'e send it to by this site, as it does not allow me to send such a large file. If you send me your email address by Fixya, I'll send it to you by return mail. OK.
How to set time?
This link goes to downloadable instructions for many LaCrosse clocks. One should work for you.
My clock reset itself for daylight savings time,
Did you try adjusting the time manually? Did you adjust the time zone/ city setting on them as well? If you need further assistance give me the exact model and i can assist you further.
Thank you,
Lee
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
