20 Most Recent
Sony CFD G505 Boombox Questions & Answers
I cant turn it on
One of the most common failures is the actual AC inlet. Have you tried using batteries? If the batteries work, I would guess that either the AC inlet has broken or that one of the connections to the transformer has broken. Either repair is not particulalry expensive. Getting at these parts can be a bit tricky though. Try running on batteries and update this with the results.
Thanks,
Dan
My Sony CFD G505 sometimes
hello .should the laser be weak and not just dusty a repair would be impractical as our labor is 90$ before the part cost.. from the picture it looks like a top loader in which case you could manually clean the laser with a simple q-tip---gently in a circle clean the lens dry q-tip no liquid .. also does it fail with different discs? if only with one that disc might be scratched ,dirty etc..
