20 Most Recent Dell AX210 2 Speakers Questions & Answers
Studio 1735
Could the source be on another mode? For example, Its on tuner and not on aux or vise versa
7/12/2014 2:00:52 AM • Dell AX210 2... • Answered on Jul 12, 2014
0answers
0answers
0answers
Disassemble
Be the first to answer 10/18/2013 5:39:54 AM • Dell AX210 2... • Posted on Oct 18, 2013Be the first to answer
0answers
0answers
0answers
My speakers were working fine
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it if his does not fix the problem click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps you if you dont have a motherboard disc you will have to download the drivers
8/26/2011 4:57:13 PM • Dell AX210 2... • Answered on Aug 26, 2011
I took the plug out of the green outlet to move
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
6/18/2011 12:12:52 AM • Dell AX210 2... • Answered on Jun 18, 2011
Not getting any sound out
Hello packiohn,
go to this "Website," and "Fill-in" or {Choose} any information needed to get the "Drivers" you need. Than you'll be able to "Download the Drivers."
"Please let me know if you 'need' further assistance, or the 'solution' helped? "By posting a 'Comment" or 'Rating' the solution. Thank you; your 'response' is important to me!"
paul7of9
Click here for Drivers: http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INSP_DSKTP_580&os=W764&osl=en&catid=&impid=
Click for Manual Download: http://support.dell.com/support/edocs/acc/P173246/MultLang/AX210.pdf
3/1/2011 1:52:59 PM • Dell AX210 2... • Answered on Mar 01, 2011
How many watts is it?
Nominal Output Power Total of 1.2 Watt .
2/16/2011 11:59:43 PM • Dell AX210 2... • Answered on Feb 16, 2011
All plugs are in and no sound is coming from
i think you have a busted speaker, try a replacemant
2/4/2011 2:42:53 AM • Dell AX210 2... • Answered on Feb 04, 2011
No sound not working everything is plugged in
if your computer came with a motherboard disc the sound drivers could be on it you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling a yellow? question mark means you need to install/update driver to do this right click to install driver also click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) hope this helps
2/1/2011 4:02:55 PM • Dell AX210 2... • Answered on Feb 01, 2011
No sounds coming out from
  • Check that it is turned on with correct power supply
  • check your sound of OS
  • check that you have the audio driver of PC
1/13/2011 4:53:47 AM • Dell AX210 2... • Answered on Jan 13, 2011
I have to turn them up full blast for normal sound
did it work louder before?, volume up all controls. anyway you can't expect a lot from this normal use speaker, this only for sounds not for entertaining.
12/21/2010 6:02:56 PM • Dell AX210 2... • Answered on Dec 21, 2010
I have dell ax210 -2
Your speakers don't require any special drivers. All they do is take the analog sound signal from the computer, amplify it and play it for you. If the sound hardware is working, all you need to do is plug in the speakers. The green signal plug goes into the output jack on the computer, and you need to connect the USB plug to an open port for power. Your computer needs driver software for its sound hardware, though, and if you're trying to solve a "no sound" problem, this may be the cause.
You don't give a make and model of your computer or sound card, so I can't give you a specific link. But you can get the drivers from the computer manufacturer's site. If you have a custom-built computer or are using a separate sound card, you'll need to get the sound drivers from the motherboard manufacturer (if it's integrated sound) or sound card manufacturer.
12/16/2010 12:33:26 PM • Dell AX210 2... • Answered on Dec 16, 2010
2answers
My speakers are making voices and music and any
you will need to locate the volume button at the bottom right hand off desktop and change the volume settings, i cant say exactly witch setting to change because i don't know what software you are using. But something in those settings is causing this.
Any further questions please ask.
Correct? vote would be usefull.# Thanks.
11/19/2010 11:37:16 PM • Dell AX210 2... • Answered on Nov 19, 2010
I have no sound from my speakers and they are
Ensure they are plugged into the right port. If you have a multi-colored port. Ensure you plug the jack into the Green colored one
10/7/2010 1:38:57 PM • Dell AX210 2... • Answered on Oct 07, 2010
Dell AX210 2 Speakers Logo
36 questions posted
Top Dell Audio Players & Recorders Experts
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
 Grubhead
Grubhead
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Dell Audio Players & Recorders
Most Popular Question
no sounds coming out from
  • Audio Players & Recorders
