20 Most Recent Liebherr KGK 2833 Comfort Bottom Freezer Refrigerator Questions & Answers
0answers
0answers
0answers
How should I set the temperature. The
Basically the thermostat controlls the freezer temperature which turns the compressor on and off.
The refrigerator section receives cold air from the freezer to cool it down.
So when the freezer is off there may not be enough cold air left for the refrigerator.
Fridges can never give you a perfect temperature every time there will always be a drift one way or another.
Once you reset the temperature the numbers or an led should blink at you to confirm the changes you made
3/25/2011 4:54:26 AM • Liebherr KGK... • Answered on Mar 25, 2011
0answers
Fridge is not cold -temp sitting at 17 c
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
12/27/2010 11:15:33 PM • Liebherr KGK... • Answered on Dec 27, 2010
2answers
REd light is flashing over
Hi!!Check temp. settings, If temp is too warm the fridge starts beeping and flashing the lights. the most common problems are:
  • Ice build up on freezer back wall or evaporator, take a look behind the drawers, it should not have any ice build up.
  • Bad Evaporator Fan Motor or dirty Evaporator Coils,
  • Defective Door Seal/Gasket
  • Bad Defrost Heater
  • Defective Thermostat
  • Bad Compressor or Freon Gas low
Unplug power cord from wall outlet for 5 min., plug it back up and check that the compressor and condenser fan on the back are working, open the freezer and check that the evaporator fan is working. Good Luck! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
11/17/2010 12:12:07 PM • Liebherr KGK... • Answered on Nov 17, 2010
Discovered water collecting in bottom of
Hello, I would check and make sure that the drainage line has'nt frozen up or come off..
9/9/2010 10:49:45 PM • Liebherr KGK... • Answered on Sep 09, 2010
Fan and motor (forced air)where to by spares
get the part number , you'll find it in the body of individual parts. You need that to find where to get it
11/6/2009 9:26:10 AM • Liebherr KGK... • Answered on Nov 06, 2009
Liebherr fridge model CS1231. How to turn off demo mode on it please?
DemoMode
Liebherr Appliances https://home.liebherr.com > hau > apac > pdf PDF Demo Mode can only be switched off via the service menu, not by pressing ON/OFF nor by disconnecting the appliance from the mains. Once "SuperFrost" has been ... 20 pages
8/7/2023 11:00:09 PM • Liebherr... • Answered on Aug 07, 2023
2answers
Liebherr freezer working, refrigerator doesn't
Take the cover off the fridge fan and put a flash light in there and a camera set to record. close the door for a couple of minutes and then look at the footage to see if the fan is running. The circulation fan should run all the time.
4/5/2023 4:16:50 AM • Liebherr... • Answered on Apr 05, 2023
2answers
LIEBHERR CBNes 39560 Fridge - ice in the drainage trough on the back?
Question edited for correct spelling of the maker. Question moved to maker category. Check the temperature of the fridge with a digital thermometer. I should be 5' centigrade. It may be set too cold and freezing condensation running on the rear wall. Also make sure the circulation fan is working. It looks like it is the round disc at the top rear. Push a flexible net curtain wire down the drain until it appears above the compressor pan. You can also try cleaning the drainage trough, dry it and spray it with dry silicone spray or even WD40 if you don't mind the smell. That will stop water sticking. https://mediamarkt.pl/agd/lodowka-liebherr-cbnes-39560 ..
3/29/2023 5:02:00 PM • Liebherr... • Answered on Mar 29, 2023
Liebherr CUN 3033 The super frost button flashes together with the temperature display. how to reset it?
Resetting your Liebherr CUN 3033 is a fairly simple process. To begin, make sure the appliance is unplugged from the power outlet. Once this is done, press and hold the super frost button for roughly 10 seconds. The appliance should then be reset and ready to use.
1/18/2023 5:44:12 PM • Liebherr... • Answered on Jan 18, 2023
Short power outage confuses Liebherr CbNes 39560 temperature regulation
Unplug it from the mains for 5 minutes to reset the main control board. It is confused by a short disconnect and more confused as it went through its self test procedure. https://www.google.com/search?q=Liebherr+CbNes+39560+reset ..
7/22/2022 1:38:01 PM • Liebherr... • Answered on Jul 22, 2022
Liebherr KGK 2833 Comfort Bottom Freezer Refrigerator Logo
27 questions posted
Top Liebherr Refrigerators Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Ngoro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Liebherr Refrigerators
Most Popular Question
red light flashing over
  • Refrigerators
