20 Most Recent
Linksys WRT120N Wireless Router Questions & Answers
Reset password to the router and get a new one
Are you trying to reset the router password or wireless network password?Wireless network password is different than router access password.To change the wireless password, you will need to access the router page and change the settings.See
how to find wireless network passwordTo change the router access password, you can log in to router page and go to administration tab. There you will find the place to change the router password.
I want to connect d'link 2640t to linksys
This is too involved to just post your router settings. I would recommend reading up on how to "cascade" your router or to make your Modem/Router act as a bridge.
The dlink will need to have its DNS disabled and have the Linksys do the DNS. Then the LInksys will be using the Dlink as its host. you may be better off seeing if you can make the dlink run in Gateway mode instead of router mode.
Then see how to implement the cascading router with your particular situation and WAN IP.
Linksys wrt120N router serup
Please connect the router and open 192.168.1.1 and enter the login page of the router with
username=blank
Password =ADMIN
Once you are in the router page select the basic wireless settings.
Under this if you want you can select the security.
Once this is set
save the settings.
Will wok fine.
Wrt120n hacked
Press the reset button on the router for 30 seconds.
Once its completed you will be able to login with default password.
My wrt120n was hacked
Please reset the router by pressing the reset button while your router should be plugged in to the power cable.
While reseting the router the lights on the router should be blinking for 30 seconds.
Try this this should work.
Can i use my WRT120N on neighbors WiFi Network
Hello there,
You cannot use this router to connect to your neighbour's router wirelessly. It is possible to share your neighbours internet connection with this router, only if you run a cable between. You will need a Range Extender or a Wireless repeater for this purpose.
How can i and what would i need
10.0.0.1 is called local loop not host ..not an IP OR DHCP address..if u want to use his wifi connection u just need to config ur wirless adapter with his router..not ur router to his router.. u also need to fig out what and how he is config...CABLE or BROADBAND ..>?
not all wirless is compatible with all routers such as PPOE OR CABLE ETC>> contact his provider for the settings u need..BOOST attenennas are cheap now and can give u a stronger signal\
Chadman
04021992
On the back of the router will be a pin hole labeled reset. Insert a paper clip and press the button for about 10 seconds. This will factory reset the router.
Can't reset router won't take blank user and "admin" password"
To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of the router with the power ON for 20 secs. then release the RESET button. To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router. Connect a LAN cable from the Linksys to the LAN port on your computer. Open a browser and enter the Linksys configuration URL http://192.168.1.1 The default login = admin The default PW = admin You can protect your router by changing the default admin PW (write it down and put it in a safe place) Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access. Now apply these settings to the wireless card in your laptop/computer. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
How to set up
Need the security code for the WRT120N wireless router
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router. Connect a LAN cable from the Linksys to the LAN port on your computer. Open a browser and enter the Linksys configuration URL http://192.168.1.1 The default login = admin The default PW = admin You can protect your router by changing the default admin PW (write it down and put it in a safe place) Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption. Now apply these settings to the wireless card in your laptop/computer. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
All the lights are on but no wifi connection.. and pc connection is also lost.
First, remove power from both, remove batteries, plug in wireless access point (Linksys) allow it to run a self test. Is it secured with a password? Plug in laptop/pc, boot normally. If that fails reset the Linksys to factory settings by pushing and holding the reset button for 30 seconds or so. Reconfigure your Linksys SSID and password. Respob to post for more info.
Can't login with default settings??
Try reseting your router using the reset button on the back. Plug in router, insert pen into reset hole and hold for 15 to 20 seconds. Then try default password and login
Forgot password to router
Follow the instructions here to reset and change the password to your WRT120N router.http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=21872
WRT120N ROUTER TO KINDLE FIRE
To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router.Connect a LAN cable from the Linksys to the LAN port on your computer.Open a browser and enter the Linksys configuration URLhttp://192.168.1.1The default login = adminThe default PW = adminYou can protect your router by changing the default admin PW (write it down andput it in a safe place)Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.Now apply these settings to the wireless card in your laptop/computer.To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-
