20 Most Recent
Encore ENHWIN3 Wireless Router Questions & Answers
Cant login to set up because its in repeater mode
plug the repeater directly into your computer via ethernet lead. then click start and either click run(on Win XP) or type cmd in the search box (windows 7 & Vista). A black command prompt window will open. Now type ipconfig and find the default ip address that will be the ip address of the repeater login using your internet explorer and in the address bar type the ip address you found for default gateway
Setup password
type in your browser 192.168.1.1 and log in to your router and setup there... :D
Forgot password username
I believe this model has a reset button in the back. Hold it in with a pin till it cycles through. This will clear all custom settings and reset to factory.
Can't find the PIN of this product
Good morning. There is no PIN to find on the router. You get the PIN from the Wireless client and enter into the router setup screen.The wireless router supports two types of WPS, the WPS via Push Button and WPS via PIN code. If you want to use the Push Button, you have to push a specific button on the wireless client or in the utility of the wireless client to start the WPS mode, and switch the wireless router to WPS mode. You can simply push the WPS button of the wireless router, or click the 'Start to Process' button in the web configuration interface. If you want to use the PIN code, you have to know the PIN code of the wireless client and switch it to WPS mode, then fill-in the PIN code of the wireless client through the web configuration interface of the wireless router.Here is the link for the Owners Manual for your router..http://www.encore-usa.com/us/sites/default/files/product_documents/ENHWI-N3_UM.pdfHope this helps..
