Disassembly? Same as the NV78 Series,
http://www.insidemylaptop.com/disassemble-gateway-nv7802u-laptop/The Ram Memory is on the bottom of the motherboard. So is the Processor. (CPU)You have to disassemble from the Keyboard down, and remove the Motherboard.1) Remove ALL power. Remove the AC adapter (Charger), and Battery.2) Work on a table. Do Not work on a bed, couch, or directly on a carpet floor. HIGH areas of -> Static electricity.Suggest lay a soft Static free cloth on the table you're working on.Helps prevent scratching the laptop, and the table.Laptop closed, turn it over, lay it bottom side up on the table.3) Don your ESD wrist strap.Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.Wear an ESD wrist strap, and have it's alligator clip attached to a good ground source, and your laptop is safe.Don't wear an ESD wrist strap, and you can use your motherboard for a Frisbee. (Processor for a neck fob, ram memory for Christmas decorations)Average cost is around $3 to $6. Here is but one example,
http://www.radioshack.com/product/index.jsp?productId=21032454) Remove the Harddrive Compartment Cover, and Memory Compartment Cover.A) Remove the Ram Memory. Ease the Spring Clips out a little bit to unlock the Ram Memory module/s. The Ram Memory module will slightly spring up at an angle. REMOVE ram memory module AT that angle.If you lift straight up you will damage the contact pins in the Ram Memory slot.[To reinstall, Ram Memory module goes back in at THAT angle. Once assured it is seated well in the Ram Memory slot; push it down to lock it in the spring clips ]B) Remove the Harddrive.The Harddrive is inside a metal Harddrive Caddy. A sheet metal enclosure. Remove the Harddrive with the Harddrive Caddy.Remove any screws holding the Harddrive Caddy in, grasp the Mylar strip, pull the Harddrive towards the outside of the laptop, and unplug it. Lift up at an angle, lifting on Mylar strip side, and remove.5) Remove the single Philips head screw holding the DVD drive in place, remove the DVD drive.(No.1 Philips screwdriver, or equivalent Jewelers screwdriver)6) Remove the 3 Philips head screws down in the Battery Compartment.Turn the laptop over to it's normal position, open it up.Remove the Keyboard Cover (Gateway terminology. In pictorial disassembly it is called the LED Board Cover)When removing, BE AWARE that there is a Multimedia Cable still attached to the Multimedia Board. (Multimedia Board is attached to the bottom of the Keyboard Cover)Gently pop the Keyboard Cover loose. I DO NOT recommend using a metal tool! Use a thick guitar pick to start, ease off with fingertips; OR use a Spudger Tool,
http://www.amazon.com/Techni-Tool-Spudger-Alignment-Tool-Black/dp/B000PDNPYKhttp://www.wisegeek.com/what-is-a-spudger.htmThe Multimedia Board in the Keyboard Cover, has a cable just like a Keyboard Cable. It is an FFC. Flat Flex Cable.One example,
http://en.wikipedia.org/wiki/File:Flat-Flex-Cable.jpgAs you can see, there is NO plug connector on the end of the cable.The FFC slides into a motherboard connector, that is a style of ZIF connector. Zero Insertion Force.Slides into the BODY of the motherboard connector, and is locked in place by a Wedge design. The Locking Bar wedges against it.The Multimedia Board Cable's flat bar terminal strips, line up with contact pins on the motherboard connector.The Multimedia Board Cable MUST go back in the same position, as it was when originally installed.Even if it's twisted, flopped over, or going to Hawaii for vacation(?).For this reason, you may wish to make a mark on one side of the cable, and a matching mark on the same side of the motherboard's connector. (Sharpee?)Do the same for the Keyboard Cable, and all flat flex cables if you wish.IF, the motherboard connector is broken for the Multimedia Board Cable, or Keyboard Cable, or Touchpad Cable, or any flat flex cable; your are looking at MOTHERBOARD REPLACEMENT, and why I am being so detailed.The Multimedia Board Cable's motherboard connector, is supposed to be what I deem, the Flip-Up style.This is a better illustration of how to open that connector,Flip-Up style:Closed/Locked,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/big/laptop-disassembly-13.jpgOpen/Unlocked,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/big/laptop-disassembly-14.jpgUse the Mylar tape on the Multimedia Board Cable, to remove it from the motherboard connector after unlocked.Lay the Keyboard Cover aside.7) Remove the Keyboard:The Keyboard has TABS on your side. They slide under the Palm Rest Cover. Lift the Keyboard at a slight angle on the LCD screen side, slide it towards the LCD screen JUST a little.Lift the Keyboard on the LCD screen side, roll it over towards you, lay on the Palm Rest Cover.Disconnect the Keyboard Cable from the motherboard connector.Shows it to be what I deem the Sliding style.Here is another example of that style of motherboard connector, only in more detail,Sliding type:Closed/Locked,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L675D-L670D/big-body/dismantle-laptop-10.jpgOpen/Unlocked,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L675D-L670D/big-body/dismantle-laptop-11.jpgAs you can see, in the Locked position all you see are two 'Tabs' of the sliding Locking Bar.Use your Thumbnails to GENTLY ease it open. Using a metal tool is DU-MB. One slip, and you break the motherboard connector, or stab the motherboard.The Locking Bar only moves about 2mm. That is a little more than 1/16th of an Inch, or about the width of this capital letter -> O <-8) Close the laptop, turn it over. Remove the Wireless Module.There are two Wireless Antenna wires. One Black, one White.Make a note as to WHICH terminals on the Wireless Module, that they go to. [Black to Main {1} White to Aux {2} ]The Wireless Antenna wire's connector clip, slides off to remove.Remove the Philips head screw which holds the Wireless Module in place, remove the Wireless Module. Makes it MUCH easier to access the Wireless Antenna wires.The Wireless Antenna wires STAY with the Display Assembly.They go up into the Display Assembly, and are connected to the Wireless Antenna.The Wireless Antenna wires are threaded, ('fished') up through the cavity hole in the laptop; and laid to the right side out of the way.(Gently pull one wire from the top with one hand, while easing the wire up from the bottom with the other hand)The Wireless Antenna wires go through CHANNELS and LATCHES.They MUST be reinstalled in the same routing as they were originally! Failure to do so, will NOT let the laptop close properly when reassembling, and MAY cause damage to the wires! (Pinched/Broken)You can lay the laptop on it's side to ease facilitation of removal.Fish the Wireless Antenna wires up, and out.More in a Comment.Regards, joecoolvette
