20 Most Recent Dell Inspiron 580 Desktop Computer (Intel CORE I3 530 640GB4GB) (DDCWYB6) Questions & Answers
try one ram at a time.
trying cleaning all fans.
check heat sink paste on your processor to make sure you are not over heating.
Dell Inspiron... | Answered on Apr 05, 2015
check cpu.check fuse in plug.
check all what runs your power.
Insert the installation disk that came with the machine. Turn off the machine, then turn on the machine and on the menu screen select install..... but before you do, make sure you have the product key on hand, because it will ask you for the 25 digit product key.
Dell Inspiron... | Answered on Aug 01, 2014
The hard drive may be failing, or just the OS or hard drive corrupted. You could try this... Pull the hard drive out, and use a USB Hard Drive Adapter to connect the hard drive to a friend's computer, and save all the personal files (documents, pictures, etc.) you can to a folder on the friend's computer or an external hard drive.
Then, you could try to do a Factory Restore on the computer, and if that works, copy your personal files back to your newly restored computer.
Good luck.
Dell Inspiron... | Answered on Jul 27, 2014
You have to do a password reset to unlock all (advanced) BIOS features. See the service manual (link below) page 33 + 34 how to do this. Take a good look at the picture, memorize the procedure, shutdown PC, unplug from mains, remove cover, find the PSWD jumper, move jumper from 2-3 to 1-2, wait 1/2 minute ( or less), reinstall the jumper to 2-3, ......... restart and hit F2 to enter BIOS SETUP ....... link to service manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_inspiron_desktop/inspiron-580_service%20manual_en-us.pdf
Dell Inspiron... | Answered on Jan 19, 2014
Contact your PC's manufacture and ask for the proper settings or you may be able to Google search it by typing in your PC make and Model and then ask how the bios settings are supposed to be set at.
I’m happy to help further over the phone at https://www.6ya.com/expert/phillip_293d34ebcf028794
Dell Inspiron... | Answered on Dec 23, 2013
Just go into the menu and perform a factory reset.
Dell Inspiron... | Answered on Nov 18, 2013
Set the time and date in BIOS. Replace the CMOS battery if it continues to fail.
Dell Inspiron... | Answered on Jan 31, 2013
It's a generic Windows message, and is exactly what is says. For instance if you execute a game twice, you would get that error for the second instance.
If you don't see a second. Check Task Manager and kill (stop) there.
Dell Inspiron... | Answered on Sep 30, 2012
hello,
check if the router has support for win 7 ,if not search for win vista,the instalations(i mean the configuration page you should run in internet explorer) look at the link provided with the router and follow the instruction
Dell Inspiron... | Answered on Sep 27, 2012
Try accessing the system restore partition by cold booting holding down the F8 or F10 key. If this works, backup your HDD to the optical drive and replace the HDD.
Dell Inspiron... | Answered on Jun 28, 2012
do you have another card slot to use? try it there and make sure it's seated well btw, you might check to see it's compatible with Dell too, since the card is not plugging into the windows 7 software.
Dell Inspiron... | Answered on May 29, 2012
Hi Good day!! try to re install your sound driver using your cd, or you can download it from here: http://www.dell.com/support/drivers/us/en/19 select your operating system and select audio driver
Dell Inspiron... | Answered on May 04, 2012
Use caution when working inside the power supply. If you don't see a fuse in the power supply, OR you come to find that the fuse is not damagaed then you will likely need to replace the power supply. I have only come across Conpaq psu units with replacable fuses in them.
Dell Inspiron... | Answered on Apr 25, 2012
If you still can see the LED light, it commons when a problems with your motherboad. Otherwise when no light at all, then check out your power supply.
Dell Inspiron... | Answered on Apr 24, 2012
If you have hard disk problems then this can cause many other problems on your computer, including impacting on performance due to the resources which are used in handling and trying to correct the disk problems.
I would strongly recommend that you make a full backup of your computer while it is still working and before the hard disk fails completely.
If you are using Windows 7 then you can do this using the Windows Backup process to make a System Image backup which can then be used to recover your system provided the image is written to either an external USB hard drive or to DVD discs.
If you have a different version of Windows, then you should try using one of the free Backup programs such as Easeus Todo Backup or Paragon Backup & Recovery Free - the links for these are below:
http://www.todo-backup.com/
http://www.paragon-software.com/free/
If you want to replace the failing hard disk yourself (after you have made a full backup as advised above) then see the Dell Inspiron 580 Service Manual for details on how to do this.
Dell Inspiron... | Answered on Jan 06, 2012
Blue screen could be the windows files getting corrupted due to a virus, file fragmentation or a failing hard drive, overheating cpu or failing memory.
The beeping usually indicates a hardware failure, first open the computer and see it the CPU heatsink is in place properly seated and fan is connected and spinning.
Second with the PC off, remove and reinsert the memory.
These are just a few things to check , most likely the hard drive has failed and needs replacing.
pressing certain keys during bootup can sometimes isolate the issue, but only if the monitor still shows a picture
I hope this helps
Thanks
Roety
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Dell Inspiron... | Answered on Aug 23, 2011
You can manually open the CD tray with a straighten paper clip.
There is a tiny hole below the tray, push the paper clip into this hole and the tray will pop out slightly. You can then grab this tray and pull it out all the way.
Dell Inspiron... | Answered on Feb 27, 2011
Dell Inspiron 580 Desktop Computer (Intel CORE I3 530 640GB4GB) (DDCWYB6) Logo
36 questions posted
Ekse
Alun Cox
Thomas F. Schneider
View Most Popular
Inspiron Dell
  • Inspiron Dell
Most Popular Question
trying make dell inspiron 580 computer
  • Computers & Internet
