20 Most Recent Dell Precision T3500 Computer Workstation (Intel Xeon W3503 80GB1GB) (BW1S1360) PC Desktop Questions & Answers
In order to make absolutely sure that HMA.Boot has not affected your computer, you have the following options:
  1. Carry out a full scan of your computer using Panda Antivirus, after checking that it is updated. If it isn't and you are a registered
  2. Check the computer with Panda ActiveScan, Panda Security's free, online scanner, which will quickly detect any possible viruses.
  3. fo more details see http://www.pandasecurity.com/homeusers/security-info/7374/remove/HMA.Boot
Dell Precision... | Answered on May 27, 2015
  3. VISIT http://www.pandasecurity.com/homeusers/security-info/7374/remove/HMA.Boot
Dell Precision... | Answered on Jun 11, 2014
what orientation are we talking about? CDROM and DVD Drives work sideways and horizontally, notice the plastic holders when you open your drive door, the cd/dvd won't drop to the floor...
No action is required on your part, everything will work as normal?
Any question? let me know.
Dell Precision... | Answered on Jan 19, 2013
Replace the keyboard, they are not made to be serviced,
Dell Precision... | Answered on Dec 25, 2012
Easier to buy a set of external speakers. Just make sure you have a sound card that has a port to plug the speaker into. If not it's still easier to buy a PCI Sound Card and a set of speakers.
Dell Precision... | Answered on May 12, 2012
If the drive won't open you can use an unfolded paperclip and insert it in the small hole (paperclip size). Push in and it will pop out.
Dell Precision... | Answered on Mar 07, 2011
  • 1
    Determine what kind of video line-in connection the TV has. These connections are typically on the back or side of the TV. You also will need to determine what kind of video line-out connection the computer has.
    Types of video connections include S-Video, VGA, DVI and HDMI. The Resources section of this article offers links to sites that will help you identify the connection type of your TV and computer.
  • 2
    Purchase a video connection cable that is for the type of connection that the computer and TV share. For example, if the TV and computer both have S-Video ports, you should purchase an S-Video cable. S-Video connections are the most common and least expensive option.
  • 3
    Connect the end of the S-Video cable that matches the connection on the computer to the computer video line-out port. Connect the other end to the video line-in port of the same kind on the TV.
  • 4
    Convert video from VGA video to S-Video or even component video. Do this if the two connection ports on the computer and TV are not compatible. You will need to purchase a scan converter box, a VGA video cable, and either an S-Video or component video cable. Connect the cable that will connect to the computer jack to the computer and the converter box, and connect the S-Video or component video cable to the TV and the converter box.
  • 5
    Turn on the TV and use the remote control to select "Input." Some TVs will have multiple selections. Turn on the computer and play a movie or display an image on the screen. As you are scrolling through the "Input" options on the television, you will see a matching image of what you opened on your computer on the TV screen when the correct input is selected.
  • 6
    Adjust the screen resolution on the computer if the image on the TV is distorted, too small or too large. Do this by going into Control Panel and Display Settings on the computer. Select a different screen resolution until the image on the TV fits the TV screen
  • Dell Precision... | Answered on Oct 28, 2010
    this 2007 year PC OLD, has many limits (CORE 2 is one)
    is this windows 10? 64bit> I bet not its CORE 2 old)
    I came with VISTA if MS loaded OS, or XP or RedHat Linux?
    what boot menu are you talking about.? F12?
    wild guess me, VISTA OS: (now zero support)
    in windows, we have disk manager, do all devices show up now?
    this is first, if not here, explorer can not work.
    lets do the correct order:
    1: bios sees my media. (good)
    2: then in device manager, it sees them, if not drivers bad.
    3: then Diskmanager sees the devices, and must have drive letter or next. if letters missing right click device and add one.
    4: explorer (This PC) fails to find it. if above fails sure.
    easy as 1,2,3,4 order, matters.
    can't see CD does that mean a disk or the whole drive?
    cant See HDD, is this HDD0 ,1,2, 3 or?
    how many HDD do you have, and are there SSD drives there
    and last what SATA ports are you using, some are limited.
    here is your DELL.com support page, (12 years later still here)
    https://www.dell.com/support/home/us/en/04/product-support/product/precision-t7400/drivers
    what HDD fails,
    does the PC boot at all? my wild guess NO.
    what OS
    what OS do you want to run, that be first thing to ask on any 2007 old PC, as Windows 10 will fail here. I Bet. for sure 64bit.
    Dell Precision... | Answered on Jun 30, 2019
    Could be a faulty psu or disk drive - suggest test both
    Dell Precision... | Answered on Mar 04, 2018
    If not data on the flash drive I suggest try reformatting the drive to remove any malware
    Many Dell can be a bit funny about exactly what RAM they will accept == check what other owners say on the Dell website user forums ..
    Dell Precision... | Answered on Mar 30, 2016
    At power-on, use F12 (or F8) and select 'Repair' ... DO NOT let it 'reformat' your drive or you will loose everything ..
    If that fails, you may have to choose 'Factory Restore', but this will re-install Windows and you will LOOSE EVERYTHING !!
    SO == if you have another PC, I suggest move your disk drive to that other PC and copy off all your photos/music/videoa etc you don't want to loose before doinbg a Factory Restore ..
    It's simple. If you still have a problem please take a look at manual in pdf file for this dell t3500. You can find it here for example:
    User manual for Dell T3500
    Dell Precision... | Answered on Sep 19, 2015
    Windows 10 is new and still in testing phase, new patches are released to fix bugs almost everyday. try running an update, make sure your hardware was compatible and the OS is installed properly, you do have the option to roll back if you want to.
    call 1-877-805-1027 for expert help.
    Dell Precision... | Answered on Aug 21, 2015
    PCProtect is malware. What is PCProtect exe . I would boot up in Safe Mode again, or Normal if you have to, and bring up Task Manager again (Ctrl-Alt-Del) and check to see if explorer.exe is running. If not, Click on File in the Task Manager toolbar, select New Task (Run), and type explorer.exe in the Open box and click OK. If all goes well, your icons and Start Menu will appear and you can start cleaning up. Otherwise, you could try again and type appwiz.cpl in the Open box to bring up the Programs and Features to remove any bad programs you may find. Malware removal can takes years of experience, so I will leave it at that to try for a starting point.
    Dell Precision... | Answered on Jul 31, 2015
    Dell Precision T3500 Computer Workstation (Intel Xeon W3503 80GB1GB) (BW1S1360) PC Desktop Logo
    Popular Tags
    15 questions posted
    Ekse
    Alun Cox
    Thomas F. Schneider
    View Most Popular
    Precision Dell
    • Precision Dell
    Most Popular Question
    remove
    • Computers & Internet
