20 Most Recent
Canon PIXMA MX320 Color USB InkJet Printer Questions & Answers
Scanner says black ink volume
Your black catridge might be over flow through its head.... so to solve your problem rub them neatly with toilet paper and replace it..... now your printer is ready to use... thanks
Canon MX320 Printer getting code
Please reset the printer
1. Turn off your printer
2. Press and hold the
STOP/RESET button
3. Press and hold Power ON button
4. While
holding the Power ON button, release the STOP/RESET button
5. While
holding still the Power ON button, press twice the STOP/RESET button
6.
Release the Power ON button
7. Wait until it display an "idle"
message. It will take about a minute.
8. When "idle" appear, open
the top cover to expose the cartridges.
9. Lift up the cover for
cartridge holder and take out both the black and color cartridges
10.
Return the cover of cartridge holder and turn off the printer
11.
Return the top cover and turn on the printer again
12. After the
printer initialize, return the cartridges.
1. Press and Hold the
STOP/RESET button and wait until it self restart.
2. Release the
STOP/RESET button the the printer is restarting.
3. Wait for a few
seconds
Canon pixma mx 320 error 5800
there are two ways you can remove the error message from your printer..
the
first is to reset the printer and the second is to replace the waste ink
absorber. If the reset thing did not work for your then you'll be
spending money to replace the absorber.
How to reset? follow these steps
STOP/RESET button
4. While
5. While
6.
10.
11.
12. After the
Hope that solve the waste ink absorber in your printer..
Printer error 6000
Hi check paper feed for blockage. & Turn power of at the PowerPoint..& turn back on.good luck..
Canon mx320 error code 21550
Remove both power and usb cables completely then connect them and use the fastest usb port on your computer.
worked for me.
could also mean cables are old and needs replacing
Contacte centro servicio
quiero cambiar el idioma de una canon mx320 esta en arqabe y lo quiero en espa?ol me pueden ayudar
