20 Most Recent
Infinity BassLink II Car Subwoofer Questions & Answers
My basslink worked great, son blew fuse, replaced, now sounds lik
If the speaker has been overdriven, it may have damaged the cone surround or damaged the speaker coil, causing it to 'rub' inside the magnet. To check for rubbing, you need to move the speaker cone backwards and forwards by hand and listen where the speaker coil/cone goes into the magnet. It should be silent if ok. If you can heara rubbing or grating noise, then the speaker is damaged. If the output driver on the amp is damaged it can give a distorted sound, which could easily happen if it tries to provide too much current.
11/4/2009 2:47:34 PM •
Infinity...
Answered
on Nov 04, 2009
Fuse blew and replaced, now sounds bad, what
Fuse is blown because you may have bad DC to DC converter circuit (step up circuit from 12vdc to provide +-/- 30~40vdc) that supplys the power amp section. I can be that the output stage of the amp shorted out and it took out the DC to DC converter circuit.
10/31/2009 1:51:56 AM •
Infinity...
Answered
on Oct 31, 2009
Infinity Bass link keeps cutting out.
Tapping into front or rear gets high level signal 3 plus volts at low impedance which is totally unsuitable for the sub's line level input which is more like 300millivolts > A competent tech could make up an attenuator patch or just take it to a professional car installer before you do more damage
ataraxia
3/23/2009 2:00:07 AM •
Infinity...
Answered
on Mar 23, 2009
Basslink keeps cutting off into protection!!
From what i have heard, If you have a speaker level input connection. this sympton does occur. You buy a scosche LOC and try giving the input to Basslink, it should work fine
8/18/2008 3:41:25 PM •
Infinity...
Answered
on Aug 18, 2008
TURN OFF NOISE
There is a static that builds on the woofer , check the wiring and check grounding of the woofer once again
4/27/2008 7:05:31 AM •
Infinity...
Answered
on Apr 27, 2008
BASS LINK II Won't stay running when car is running
You have it wired to your accesories setting, you need to wire it to to your " Run " wire. Try this, Look in your fuse box and find the fuse that only has vultage when the car is on. Use a voltemeter. Then just wrap the wire around the fuse and insert it back in.
Your cars repair manual, If you picked one up, will have a wiring diagram in the back, where it shows the starting system, it will say weather the wire is "Hot" has voltage when the car is in the "on/RUN" position, or in the Accessories position. You want to plug it into the RUN wire so that its only on when the car is on and running, this way you dont drain your battery.
Make sur eyou have a fuseable link between in the positive wire thats connected to the battery so you dont fry your sub with to much voltage.
2/29/2008 11:34:43 PM •
Infinity...
Answered
on Feb 29, 2008
Light is always on!
yes the problem is in the installation.the power supply usually has 2 to 3 positives one positive which is usually red go directly to battery.
the other,either yellow,orange,or blue go to car stereo(not to battery or ignition) this supply,turn off the amp when u turn of the stereo.
hope this help u....
5/9/2007 3:57:42 PM •
Infinity...
Answered
on May 09, 2007
Infinity BassLink II Keepps Cuting Out!
Auto cut is due to overload, check out the wattage handling capacity of the Amp & the woofer( if the impedence is too low there will be an over load for the Amp.
5/6/2007 10:44:18 PM •
Infinity...
Answered
on May 06, 2007
What is the wiring schematics for an Infinity Gold Amplifier 56007499?
hi,
if thats a dodge this might be it..
Re: Infinity Gold AMP Wire Diagram
Well I don't particularly care for
Haynes manuals, but my FSM's did not have anything either. I found this in thejeep cherokee haynes manual and it says that it is for 97 and later models but see if it is close. it looks like there are 2 harnesses so I will list them seperately:
Hartness 1:
[7] Left Soundbar Speaker (+) BR/YL
[8] Left Soundbar Speaker (-) BR/LB
[5] Left Front Door Spkr (+) DG
[1] Left Front Door Spkr (-) BR/RD
[9] Right Soundbar Speaker (+) DB/WT
[3] Right Soundbar Speaker (-) DB/OR
[6] Right Front Door Spkr (+) VT
[2] Right Front Door Spkr (-) DB/RD
[4] Power Amp Relay Feed DG/RD
Harness 2:
[05] Right Soundbar Spkr (+) TN/RD
[13] Right Soundbar Spkr (-) TN/BK
[06] Left Soundbar Spkr (+) WT/TN
[14] Left Soundbar Spkr (-) WT/BK
[11] Passenger Door Spkr (+) LB/RD
[10] Passenger Door Spkr (-) LB/BK
[04] Drivers Door Spkr (+) DG
[12] Drivers Door Spkr (-) LG/RD
[01] Power Amp Feed
[02] Power Amp Feed
[07] Power Amp Ground
[08] Power Amp Ground
The tweeters run in parallel off of the door speakers.... If I can help any more let me know.
-Mike.
https://forums.off-road.com/jeep-mid-sized/105694-infinity-gold-amp-wire-diagram.html
