20 Most Recent
Lexmark Platinum Pro905 multifunction InkJet Printer Questions & Answers
Looking for ocr software for Pro905.
The Lexmark OCR software can be downloaded using the installation disc that came with your printer only. The software is not available from the Lexmark website for download. If you lost your disc, feel free to contact Lexmark Technical Support Center for assistance.
How to connect to lexmark pro 905 wirelessly
First, make sure you connect the Lexmark to your wireless network. Select the tools (wrench icon) from the home screen. Scroll to Network Setup and enter your wireless permissions. If setup is complete and the printer successfully connects - the upper right wireless indicator will turn from orange to green. Then it's a matter of connecting your wireless device. If when setting up a new printer (or "Add Printer") you see the Lexmark in the list, then it's a simple point/click. However you might have to manually enter the IP address of the Lexmark on your device which you can find in the tools, Network Setup TC/IP menu.
Left hinge broke on lexmark pro 905
Not a perfect fix, but this is what I did: There are 2 spring-loaded pistons located on the printer side of the hinge that cause this problem. I think there should be another piece of plastic that holds the top of the printer hinge down on these springs, but when this hinge is gone, the top of the printer is held upward by them. If you use some pliers to gently pull these spring-loaded pistons upward, you can easily pull them out, followed by the springs they cover. Once removing these, the top of the printer lies flat. The top is still unstable, but mine will now feed paper just fine and closes. Hope this helps! WebRepOverall ratingThis site has no rating(not enough votes)
