20 Most Recent
Infinity KAPPA PERFECT 12.1 Car Subwoofer Questions & Answers
How do i fix an output problem?
is the cone stuck form lack of use by any chance ,try connecting to a car battery and touching a wire to complete the circuit quickly and it should go blurp if its working and this often frees the cone up if its a bit corroded
I need the dimensions for
10 x 10 x 4.6 inches ; 11.2 pounds
If it were me, I would go with a sealed box. It will hit deeper that way!
- Carbonrue67
What is the wiring schematics for an Infinity Gold Amplifier 56007499?
hi,
if thats a dodge this might be it..
Re: Infinity Gold AMP Wire Diagram
Well I don't particularly care for
Haynes manuals, but my FSM's did not have anything either. I found this in thejeep cherokee haynes manual and it says that it is for 97 and later models but see if it is close. it looks like there are 2 harnesses so I will list them seperately:
Hartness 1:
[7] Left Soundbar Speaker (+) BR/YL
[8] Left Soundbar Speaker (-) BR/LB
[5] Left Front Door Spkr (+) DG
[1] Left Front Door Spkr (-) BR/RD
[9] Right Soundbar Speaker (+) DB/WT
[3] Right Soundbar Speaker (-) DB/OR
[6] Right Front Door Spkr (+) VT
[2] Right Front Door Spkr (-) DB/RD
[4] Power Amp Relay Feed DG/RD
Harness 2:
[05] Right Soundbar Spkr (+) TN/RD
[13] Right Soundbar Spkr (-) TN/BK
[06] Left Soundbar Spkr (+) WT/TN
[14] Left Soundbar Spkr (-) WT/BK
[11] Passenger Door Spkr (+) LB/RD
[10] Passenger Door Spkr (-) LB/BK
[04] Drivers Door Spkr (+) DG
[12] Drivers Door Spkr (-) LG/RD
[01] Power Amp Feed
[02] Power Amp Feed
[07] Power Amp Ground
[08] Power Amp Ground
The tweeters run in parallel off of the door speakers.... If I can help any more let me know.
-Mike.
https://forums.off-road.com/jeep-mid-sized/105694-infinity-gold-amp-wire-diagram.html
