20 Most Recent
Dei Directed Viper Python 514n Soft Chirp Siren Questions & Answers
Kill switch auto start
your key has a transponder in it. engine will only start with the transporter, its part of the immobilizer.
2/13/2018 1:44:11 PM •
Directed...
Answered
on Feb 13, 2018
How do I remove an AM alarm with a killswitch
easy remove it , and put the wiring back to factory stock
bingo,
done many
others (installed) i use a jumper plug i design, that allows me to
unplug the alarm box, and insert a jump plug and all is back to stock.
the wiring is here. all of it.
alldata.com
i posted both ways, nice huh?
12/10/2013 4:03:48 PM •
Directed...
Answered
on Dec 10, 2013
Directed 555p instalation
it use to work untilwife jumped someone then stop working check fuses good aentenna dont work cruise dont work heat in seat stoped too any idea
12/11/2012 7:36:14 PM •
Directed...
Answered
on Dec 11, 2012
2001 Cadillac Deville Northstar Engine thermostat location
4.6 Northstar V8. It is located on the rear of engine (driver side) in front. It is in the the water pump housing cover. Remove air box and intake tube and bottom radiator hose. 2 bolts(believe 10mm) on thermostat housing. These systems are a little finicky about air pockets....so fill slowly and let run at idle until operating temp and let cool and check level.....fill as needed and repeat if needed.
Peugeot expert central locking not working
A faulty central locking system might be due to several reasons, such as a blown fuse, faulty solenoid, or electrical wiring issues. Also, it's good to remember the fault might not be with the central car locking system but the key fob instead; over time, fobs require battery changes.
