20 Most Recent
Clarion NZ500 Car Video Player Questions & Answers
NZ500 with Sirius forgets presets
There is a memory keep alive wire that is usually yellow. It should be fused, it has either blown the fuse or had become disconnected.
Does this unit fit into a 2007 montana van
This unit will fit into your van. There will be extra space in the dash after you install it. The standard measurement technique for head units is DIN. A single-DIN unit is the normal size of a head unit. Your stock unit is a double-DIN unit. The Clarion NZ500 is a single-DIN. It will fit, with space to spare.
I have the clarion nz500.
Hi and welcome to FixYa!
As a first course of action please try this... Remove the positive battery connector and let it sit for atleast 5mins. then reconnect it again. This will reset the system and can get the unit back to it's normal operation.
Hope this helps and thank you for using FixYa! Have a good one!
What does the DVD Video
Click on this link directly
http://www.hometheaterinfo.com/dvd4.htmCheck fig:--
This are basic video cables.You can all types of required video cables from ---------------
www.radioshack.com or from
www.bestbuy.com.
just mention your exact dvd model number and brand to them and they will send you the required cable.
Thanks. Keep updated for any more query. You can rate this solution and
show your appreciation.
Nz500 will not open
i have encountered same problem. mine was done through removing the negative terminal of the battery for a few minutes. fix it again and problem solved.
