20 Most Recent Sanyo VPCS885 Digital Camera Questions & Answers
Sanyo VPC-S885
Iso only can be set in other than automatic mode. Goto the image capture menu (it is the camera loge on the top bar) then second line is ISO settings. Goto that line and click to right to cycle trough the settings.
11/25/2013 9:52:31 PM • Sanyo VPCS885... • Answered on Nov 25, 2013
How do i copy pictures to my computer with the camera plugged in to the computer
Do you really want to have the camera plugged into the computer?The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). The transfer is likely to be faster than connecting the camera to the computer.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
1/21/2013 4:07:05 PM • Sanyo VPCS885... • Answered on Jan 21, 2013
I need software for my
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as iPhoto on Mac or Windows Photo Gallery or Picasa ( http://picasa.google.com ) on Windows.
8/30/2011 5:02:19 PM • Sanyo VPCS885... • Answered on Aug 30, 2011
Where can I get a manual for the Sanyo VPC S 885?
http://us.sanyo.com/dynamic/extranet/servicers/VPC-S885_OM_%20English.pdf
6/1/2011 9:17:25 PM • Sanyo VPCS885... • Answered on Jun 01, 2011
I do not have sound on my video?
did you get help?
3/5/2011 5:26:42 AM • Sanyo VPCS885... • Answered on Mar 05, 2011
I purchased this camera about 3 months ago with
This is not a very expensive camera. To get it looked at would cost over $100. If it were mine, I would throw it away and chalk it up to "lesson learned". Next time, buy a more expensive camera and don't forget to save the paperwork.
1/14/2011 11:55:33 PM • Sanyo VPCS885... • Answered on Jan 14, 2011
How do I know if my camera is a SD series, S/SX
It's an S series.
12/15/2010 3:55:42 AM • Sanyo VPCS885... • Answered on Dec 15, 2010
I have a sanyo 12.0vpc digital camera,everytime i
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
12/9/2010 4:30:54 PM • Sanyo VPCS885... • Answered on Dec 09, 2010
My camera has card locked and i cant do anything
If it has one, move the slide switch on the side of the card.
12/3/2010 8:45:15 PM • Sanyo VPCS885... • Answered on Dec 03, 2010
I have my camera plug into computer, but I don't
Consider NOT connecting the camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
11/26/2010 7:06:10 AM • Sanyo VPCS885... • Answered on Nov 26, 2010
Good am....my daughter dropped her
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
11/14/2010 1:51:56 AM • Sanyo VPCS885... • Answered on Nov 14, 2010
Tells me my card is locked
take your sd card out and there should be a little switch on the side. switch it
11/3/2010 11:35:49 PM • Sanyo VPCS885... • Answered on Nov 03, 2010
My camera want stay on it just keep turning off
This sounds like a low battery problem. Either replace the batteries with fresh ones (if they are replaceable) or recharge. If the battery won't recharge then it may have come to the end of its life.
10/18/2010 4:28:41 PM • Sanyo VPCS885... • Answered on Oct 18, 2010
How do I set the date and time
Manual for your camera can be downloaded from official web page http://sanyoservice.com/pdf/images/VPC-S885%2520English.pdf
6/2/2010 7:39:16 PM • Sanyo VPCS885... • Answered on Jun 02, 2010
2answers
Deleted photos
No worries, it is possible to recover deleted photos from camera. You may take a look at this guideHow to recover deleted photos from digital camerathe guide helped me before, easy to follow and helped me get back all my photos from my digital camera, hope that it helped you too!
3/13/2017 10:00:59 AM • Sanyo VPC... • Answered on Mar 13, 2017
The zoom on my sanyo vpc E2100 won't work at all, either in standard zoom mode or intelligent. it would work sometimes, at first. can this be fixed and would it cost very much?
From your description, it appears that the camera may have received an accidental blow, or else there is some foreign matter (sand or suchlike) in the lens mechanism. Either way, you are probably looking at professional repairs, which will be expensive, possibly prohibitively so. It may be more financially viable to replace your equipment. If you can show accidental damage has occurred, then you may be able to claim on your household insurance.
6/19/2016 10:58:26 AM • Sanyo VPC... • Answered on Jun 19, 2016
0answers
Lens error 1215
Be the first to answer 9/19/2014 2:37:29 PM • Sanyo VPC... • Posted on Sep 19, 2014Be the first to answer
2answers
Deleted photos
Recuva (pronounced "recover") is a freeware Windows utility to restore files that have been accidentally deleted from your computer. This includes files emptied from the Recycle bin as well as images and other files that have been deleted by user error from digital camera memory cards or MP3 players. It will even bring back files that have been deleted from your iPod, or by bugs, crashes and viruses!
  • Put the memory card into an USB card reader and plug it into the USB port in your computer, then run the Recuva program.
  • Simple to use interface - just click 'Scan' and choose the files you want to recover
  • Easy to use filter for results based on file name/type
  • Simple Windows like interface with List and Tree view
  • Can be run from a USB thumb drive
  • Restores all types of files, office documents, images, video, music, email, anything.
  • Supports FAT12, FAT16, FAT32, exFAT, NTFS, NTFS5 , NTFS + EFS file systems
  • Restores files from removable media (SmartMedia, Secure Digital, MemoryStick, Digital cameras, Floppy disks, Jazz Disks, Sony Memory Sticks, Compact Flash cards, Smart Media Cards, Secure Digital Cards, etc.)
  • Restores files from external ZIP drives, Firewire and USB Hard drives
  • It's fast, tiny and takes seconds to run!
Go to these WEB sites to down Recuva http://download.cnet.com/Recuva/3000-2242_4-10753287.html www.filehippo.com/download_recuva
5/7/2014 11:02:54 AM • Sanyo VPC... • Answered on May 07, 2014
0answers
Sanyo VPCS885 Digital Camera Logo
Popular Tags
19 questions posted
Top Sanyo Cameras Experts
NOEL
NOEL
Ngoro
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
View Most Popular
VPC Sanyo
  • VPC Sanyo
Most Popular Question
sanyo vpc s885
  • Cameras
