20 Most Recent
Samsung PL80 Digital Camera Questions & Answers
The canra says DCF full
Hi. The PL80 has an 86MB internal memory so it does not sound as if there is anything wrong. However you can buy an SD or SDHC memory card and use that as well, so you can take a lot more pictures.
The number of pictures which can be stored depends on the size of the internal memory, or the extra memory card, and whether you set the camera to record the images in 'Normal', 'fine', or 'super fine' mode. This determines how compressed the images will be, and how much memory each one will use up.
A 1GB card would give around 160 pictures in super fine mode. Have fun with your camera!
Where do i find the serial number
Digital Camera (Camcorder: Battery cover inside) Serial number: Bottom of the product
Hope this helps; also keep in mind that your feedback is important and I'll appreciate
your time and consideration if you leave some testimonial comment about
this answer.Thank you for using Fixya, and have a nice day.
Hi there my camera has
Depending on the age of the camera it is possible that the flash has failed, if the camera is newer and has some sort of warranty then you should be able to trade it in for a new one straight from the manufacturer.
Samsung PL100 - strange problem
Put the card back into the camera and format it.In the future, always format the camera after you finish download your pictures, instead of deleting them.
My Samsung Es90 digital camera's shutter is not working, plus, the batteries are fully charged but when inserted, it only last 2-3 minutes. What can I do to resolve this?
I'm assuming by "shutter" you're referring to the one inside the camera and not the cover blades on the very front of the lens.
How old is the battery and do you use the camera a lot?
Old batteries can be fully charged but can become weak and not hold that charge when the camera is powered on. The shutter issue could be part of this as the battery might not be strong enough to power the shutter.
I think the batteries for these cameras are reasonably cheap so you could invest in a new one to see if that helps. An extra battery is always useful if you use the camera a lot.
If this is an old, well used camera part do wear out so if new battery doesn't help you may need to take it to a good repairer as the camera will need to be taken apart to find the problem.
