20 Most Recent FUJIFILM FinePix JV100 Digital Camera Questions & Answers
follow instructions in manual
FUJIFILM FinePix... | Answered on Feb 13, 2015
Download photos from any camera is highly unrecommended because that quickly disharges the camera battery. Instead, turn camera off and then open battery door. See picture memory card at camera edge, push in and release to pop up. Then, draw card out of the slot taking care to avoid finger contact with contacts. Close battery door. No insert card into card reader on computer. (Most computers these days have built in reader. USB interface readers can be purchase at low cost.)
If the upload start up dialog does not auto star, then open Computer and double cick open it there. A menu will appear offering wholesalee import you can chose Review Folders in Explorer. Once opened, photos can be handled and stored ot computer like any other file. It is preferable to copy files as opposed to moving them, using camera itself to delete files. Now close Fuji folder and initiate safe removal. When approved, remove memory card and reinsert in camera. Question answered.
FUJIFILM FinePix... | Answered on Jan 03, 2015
Is the camera still in automatic? (green camera logo) Or is it in scene, night shot?
If you put it to automatic, and it won't change anything, I'm afraid your camera is defect. Contact a certified Fuji repair centre, but before you send it in for repair, ask what it will cost you. because camera's are becoming cheaper and cheaper. Don't pay more for a repair than you would pay for a new camera.
FUJIFILM FinePix... | Answered on Dec 22, 2014
Install the english version of the software that came with camera.
FUJIFILM FinePix... | Answered on Oct 07, 2014
Deleting or formatting won't make the data in camera erased permanently. You can still recover pictures with camera format recovery software, recommended asoftech photo recovery as I used the program before, it's quite easy to use and works well for me
http://www.asoftech.com/apr/
You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
FUJIFILM FinePix... | Answered on Dec 25, 2013
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
FUJIFILM FinePix... | Answered on Dec 16, 2013
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
FUJIFILM FinePix... | Answered on Sep 16, 2013
You only use the internal memory (24MB). Internal memory only records 41sec. Please check the settings. If HD records are recorded to internal memory.
FUJIFILM FinePix... | Answered on Mar 26, 2013
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa.
FUJIFILM FinePix... | Answered on Aug 28, 2012
FUJIFILM FinePix... | Answered on Jul 06, 2012
Here is a tip that I wrote about how to find the manuals, drivers, downloads andsupport for Digital Cameras.
DigitalCamera Manuals, Drivers, Downloads, and Support How to easilydownload Pictures from Digital Camera
heatman101
FUJIFILM FinePix... | Answered on Aug 27, 2011
Press the MENU/OK button to bring up the menu. Use cursor-left to move to the tabs then use cursor-up/down to select the SET tab (wrench icon). Use cursor-right to enter the setup menu then use cursor-up/down to select DATE/TIME (clock icon) and press MENU/OK.
FUJIFILM FinePix... | Answered on Aug 08, 2011
No. The NP-45A battery needs a separate charger. If you need a charger, one source is
http://www.overstock.com/Electronics/Battery-and-Charger-for-Olympus-Li-40B-Fuji-NP-45/6042413/product.html
FUJIFILM FinePix... | Answered on Aug 01, 2011
FUJIFILM FinePix JV100 Digital Camera Logo
75 questions posted
Top FUJIFILM Cameras Experts
Jeffrey Groves
Jeffrey Groves
Falling star
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
View Most Popular
FUJIFILM Cameras
  • FUJIFILM Cameras
Most Popular Question
recover pictures accidentally
  • Cameras
