20 Most Recent
Dyson DC31 Animal Bagless Handheld Cyclonic Vacuum Questions & Answers
Dc31 charges in a couple of minutes battery only lasts 50 seconds is it battery or charger or both ?
Hi there, it's Jack at Dyson.
I'm sorry to hear your DC31's charge isn't lasting as long as it should be. From what you've described it could be the battery that's at fault, but we'd appreciate the opportunity to talk you through some simple diagnostic checks over the phone when you have your machine to hand. By doing this we can determine exactly which part needs replacing, and avoid you ordering an unnecessary part.
You can reach the Dyson UK Helpline on 0800 298 0298. We're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends. Calls are free from UK landlines.
We'll look forward to speaking with you.
The button that holds the hose arm to the wand?
Hi Betty, it's Jack at Dyson.
If the wand locking clip has come out of place, it should just push back into position. The spring should sit under the end of the clip that you press. If you'd like our experts to talk you through it, or if part of the machine is damaged and needs replacing, please get in touch with us directly.
You can reach the Dyson Customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Need to buy new battery charging device for the
If you want to purchase a new charger assembly, you can order one directly from Dyson. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). Alternatively, you can order one online from
www.dyson.com.
Kind regards,
Jack
Dyson Customer Service
Belt replace instructions
As far as I know DC31's don't have a belt, they are direct drive. Maybe you should describe the issue you are having or maybe got the wrong model number?
Dc 31 animal: even when
Sorry to hear you're having difficulties with your DC31 Animal. It's probably best if you get in touch with us directly, so one of our experts can run through some troubleshooting over the phone with you to identify the cause of the issue. They'll be happy to recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
DC31 not working light comes on when I pull the triger
Hi Robert, it's Jack at Dyson.
If your DC31's light comes on when you pull the trigger, but the machine itself doesn't run, it could mean that the battery needs charging. I would suggest connecting it to the charger and allowing it to recharge fully for 3.5 hours.
If you find that this doesn't resolve the issue we'd appreciate the opportunity to take you through some quick diagnostic checks. This will help us to determine what may be causing the fault. and what's needed to resolve it
You can reach our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
