20 Most Recent
SkyGolf SkyCaddie SGX GPS Receiver Questions & Answers
My skycaddie is frozen [happened
The only thing you can do is dis-connect the rechargeable battery for at least 60 seconds, this should clear the microprocessor.
10/9/2016 7:29:49 PM •
SkyGolf...
Answered
on Oct 09, 2016
Sgx skycaddie will not shut
perform
a soft reset(a forced restart basically ) . hold power and joystick for 8 seconds. it will turn off.
now turn on. if boots up correctly, then ok. if not, then perform
hard reset.(remember that this will delete any information already installed..) push the information button (i) and flag button at same
time. while both buttons are pressed turn on power. you should be in
recovery mode. if so, re-sync.
10/9/2016 7:24:35 PM •
SkyGolf...
Answered
on Oct 09, 2016
I can't get my skycaddie to move.It's like it's frozen
Hi Dorothy,
The first thing you should do is remove the battery. After replacing the battery make sure it is completely charged. After that, turn your skycaddie back on and it should work normally. Make sure that you are outside with an unobscured view of the sky. When you secure access to satellite your GPS should record your movements larger than 50 yards or less. I would use my phone to verify my exact location.
Cheers,
Dr. Bob
6/11/2015 3:44:52 PM •
SkyGolf...
Answered
on Jun 11, 2015
I have a SGX and have lost the antenna cover. Can I find a replacement?
Stay AWAY from the SGX. The quality control is really poor. I know of three other users having the same problem, the antenna cover falls off and the unit does not get satelite reception. It becomes a piece of junk. Once that unit got replaced, in less than 5 months, the rubber covering the knob that allows you to select items had a tear and now the unit is no longer waterproof. This is not covered under warranty and they want you to pay $89.95 for a replacement. I am done with SkyCaddie. I have just purchased the new Garmin G6, awesome device, no annual fees, long battery life and touch screen enabled.
Look at the following link to get other user experiences.
Amazon com Customer Reviews SkyCaddie SGX Golf GPS
2/9/2015 11:52:11 PM •
SkyGolf...
Answered
on Feb 09, 2015
