20 Most Recent Office Depot Ativa DSD160D Shredder Questions & Answers
No power. Seems to be overloaded
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
11/4/2013 6:00:34 AM • Office Depot... • Answered on Nov 04, 2013
Office Depot Light Duty Paper Shredder, Model PS-028/B - how to disassemble head, and...
Note the words Light Duty. Something was shredded that damaged the mechanism. Oiling was not the cure. No amount of tinkering will save it.
8/21/2021 8:58:14 AM • Office Depot... • Answered on Aug 21, 2021
3answers
What is the shelf life of Office Depot cleaning duster. I have a can from 2008.
If you try to turn it on and it doesn't work, you will know that after ten years it went bad.
7/16/2018 3:07:18 PM • Office Depot... • Answered on Jul 16, 2018
I have an Ativa MD
ativa md460 misaligned Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your ativa md460 misaligned question. Get free help, tips ... I have an Ativa MD 460c paper shredder that reads misalignment. What do I do?
Just purchased ativa MD 460C and it will not work. misaligned
www.fixya.com/support/t9496803-just_purchased_ativa_md_460c
Jun 16, 2011 - Look for a curve in the lip on the back of the shredder and align it with the ... I have an Ativa MD 460c paper shredder that reads misalignment.
Ativa MD460 paper shredder: misalignment light is on - Fixya
www.fixya.com/.../t7580117-ativa_md460_paper_shredder_misalignme...
Jan 1, 2011 - I have a Ativa MD 1000 that I just bought. It ran for a few minutes the first time I used it an then stopped. I turned it off and unplugged it in case it had ...
Office Depot Ativa DQ60M Shredder Misaligned - Questions ...
www.fixya.com > ... > Office Depot Ativa DQ60M Shredder
just purchased ativa MD 460C and it will not work. misaligned is highlighted. can u help... I have an Ativa MD 460c paper shredder that reads misalignment.
1/8/2016 11:48:55 PM • Office Depot... • Answered on Jan 08, 2016
How do I change the battery in a Office Depot KS-1000 calculator.
Take the back off if there is a little screw unscrew it first then pop it off if there is no screw then carefully pry the sides of the to panels front and back apart...
1/30/2015 11:13:11 PM • Office Depot... • Answered on Jan 30, 2015
0answers
Office Depot Ativa DSD160D Shredder Logo
1 questions posted
Top Office Depot Office Equipment & Supplies Experts
k24674
Are you an Office Depot Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Office Depot Office Equipment & Supplies
Most Popular Question
no power seems overloaded
  • Office Equipment & Supplies
