20 Most Recent
IBM Wheelwriter 6 Typewriter Questions & Answers
Replacing the print solenoid cap
The best way to find what you are looking for is to look at your printwheel. Right in the middle of the carriage there is a part that hits the printwheel. That is called the hammer. If you look down on the left side you will see a blue piece of rubber that attaches to the hammer. If you continue to look further down the hammer you will see the solenoid that activates and hits a screw that sticks out from the hammer. The end of the solenoid is where the "cap" can be attached. You do not have to remove the solenoid to install the repair "cap" if that is what you are really looking for. A technician can put in a new cap in less that 30 seconds.
What does the print solenoid look like
What is the part number for a ww6 ribbon lift plate?
Here are the part numbers as requested as well as some others.
The ribbon plate is 1384819.
The ribbon plate assembly is 1384817.
The ribbon plate motor is 1384821.
You may want to order the whole assembly to make sure as the plate doesn't have the motor on it.
Keys strike paper but don't space
Is it all of the keys or just some of the keys don't space? Check to see if the lang light is turned on. If it is, hold down the control button (the button left of the spacebar) and hit the letter "X" and see if the light goes out.
Where is the TYPEWRITER SOLENOID on a IBM Wheelwriter 6 Series II
The "print" solenoid is what hits the hammer that hits the printwheel and makes it type on your paper. If you remove the ribbon and look straight down in the carrier on the left side you can see the solenoid. It is below the blue piece of rubber that sits on the hammer arm. The end of the solenoid is supposed to have a cap on the end of the plunger. This cap gives a specific clearance so when it is activated, it hits the hammer arm to propel it forward to strike the printwheel.
Lang light on how do I fix ?
Hold down the Control button (the button left of the spacebar) and the hit the letter "L". This will turn it off.
Memory erases when turned off
There are AA batteries in the machine and it takes either 2 or 3. You can replace them when the machine is on as that will not harm the machine or you. The batteries should be replaced every one - two years. Replacing them when the machine is turned on will allow the current memory to remain intact.
