20 Most Recent
Magnavox DV220MW9 DVD Player VCR Questions & Answers
The VCR accepts the tape and starts to play; then stops and shuts off; when you turn the power back on the tape ejects
You have a transport problem, the mechanism the plays, FF or rewinds is not working.Someone is going to have to open and look at the unit---as simple as a belt off or broken to the idler (rubber or geared) that doe the actual work, finding a shop that will work on a VCR unit is getting hard as most of the current techs have never seen this type of unit.What I used to do when I opened one was have a old cassette with the tape removed! but the reels inside of it still there--tape off both sides of the cassette where it opens so the sensors on either side do not try to stop the unit from allowing this.This way with the unit open and the dummy cassette in you can see thru its top to see if the reels are moving or not and not have the tape get in the way.
10/8/2020 4:14:20 AM •
Magnavox...
Answered
on Oct 08, 2020
Need operating manuel
http://www.m4c.magnavox.com/cgi-bin/dcbint/cpindex.pl?qslg=on&mode=search&scy=US&ctn=DV220MW9/F7&ds=DV220MW9/F7&slg=AEN&searchtext=manual&submit.x=0&submit.y=0
3/13/2016 1:35:20 AM •
Magnavox...
Answered
on Mar 13, 2016
How do you hook up cords to cable box & television
WELL IT SEEMS U HAVE TWO PROBLEMS :
1ST YOUR rF SIGNAL IS NOT GETTING THRU , THIS IS A ROUND CABLE WITH A SCREW ON END TO IT , THIS ONE MUST 1ST COME INTO YOUR HOME AND GO TO CABLE BOX , THEN LEAVE OUT OF CABLE BOX AND ENTER VCR THEN LEAVE OUT OF VCR AND GO TO RF INPUT OF TV ( HAS TO BE HOOKED THIS WAY WONT WORK ANY OTHER WAY) SET OUTPUT OF VCR TO CHANEL 3 SET OUTPUT OF CABLE BOX TO CHANNEL 3 SET TUNER OF VCR TO CHANEL 3 , AND LAST SET INPUT OF TV TO rf CABLE ,CHANEL 3 , NOW YOU CHANGE CHANELS ON CABLE BOX only
2ND YOUR DVD PLAYER HAS NO RF OUTPUT SO YOU NEED TO CONNECT BY ONE OF THESE MEANS (HDMI, RGB, COMPOSITE) ALL THESE REQUIRE A DIFFERENT CABLE YOU DECIDE , THERE HOOK UP IS PRETTY MUCH ONE WAY SO I WONT ELABORATE ON EACH METHOD , BUT TV NEEDS TO BE SET TO CORESPONDING INPUT TYPE YOU DECIDED ON
11/11/2015 2:34:13 AM •
Magnavox...
Answered
on Nov 11, 2015
Cannot open the disc tray
If you hear the motor trying to work then try to push the disk out by try holding the eject button for couple of seconds or press it and hold it couple of times real quick. If that works you need to leave disk in it in order to get the disc tray to keep ejecting I a have cdrom that works like this. If not take it apart and take out the cd you need and replace the disc tray with motor that works.
11/28/2013 10:25:00 PM •
Magnavox...
Answered
on Nov 28, 2013
