20 Most Recent
Transcend StoreJet 25 Mobile 500GB USB 20 25'' External wOne Touch Backup (Red) 500 GB Hard Drive Questions & Answers
I have an external hard
Firstly,recover your data on the external hard drive with third party data recovery software.Then you can format it to check out whether it can be fixed.
For data recovery program,I have a professional one on my computer that can recover data after deeply scanning your hard drive to look for lost data due to drive crash,system sabotage, virus attack etc.You can download it and scan your hard drive for free to preview whether your data can be recovered.
http://www.any-data-recovery.com/product/datarecoveryprofessional.htm
1/30/2017 7:29:43 PM •
Transcend...
Answered
on Jan 30, 2017
ASKS ME TO FORMAT
File-system corruption or failing hardware. If you have important data take it to a professional right away, don't mess around with it any more.
Check disk in another computer may fix the problem but it may also decrease the chances that a pro can retrieve any of your data.
4/14/2015 8:11:42 PM •
Transcend...
Answered
on Apr 14, 2015
External hard disk delay
Your drive has most likely developed bad sectors, if your data is precious do not run software recovery programs over it since this can stress the drive and cause it to fail completely, take it to a data recovery company. If you do wish to try it yourself use an imaging tool like dd_rescue for linux, also remove the drive from the USB enclosure and connect the drive directly to the machine.
3/28/2014 11:00:16 AM •
Transcend...
Answered
on Mar 28, 2014
Clicking noise and takes long to read
If the data is important I would highly recommend sending it to a specalised data recovery company, they have special hardware/software designed specifically to deal with failing hard drives. Digital Recovery (www.digitalrecovery.co.nz) are well priced and have all the gear to deal with this. If you data is not particularly important you could try removing it from the external case and imaging it in a Linux machine using dd_rescue. Download Ubuntu and install dd_rescue (sudo apt-get install dd_rescue) and have another blank drive installed then image the disk like this "dd_rescue /dev/sda dev/sdd, where sda is the faulty drive and sdd is the blank one, do not get these mixed up or you will overwrite your data.
12/30/2013 11:58:53 AM •
Transcend...
Answered
on Dec 30, 2013
My hard works sloly
while attaching to system,check whether antivirus is scanning or not, sometimes scanning of antivirus also slowed down the speed
12/23/2013 10:54:39 AM •
Transcend...
Answered
on Dec 23, 2013
My Transcend StoreJet 500GB cannot
Several things could be happening here:
1. your electronic controller in the hard case has failed.
2. you didn't properly disconnect the external hard drive in Windows > with the
"Safely Remove Hard ware and eject Media" in the task bar.
3. if you have a power supply to the USB drive it may have a damaged power connector or not supply proper power to the device.
6/17/2013 2:43:06 PM •
Transcend...
Answered
on Jun 17, 2013
Its become mega slow. i plugged it in and it was
If it's working but slow, it sounds like it's running at the USB 1.0 data rate.
Is the cable plugged directly into the USB port on your computer, and not into a USB hub.
Or it might be the cable. Have you changed the cable?
Both cable and hub, if you really need a hub, need to rated for USB 2.0
6/9/2013 9:48:47 PM •
Transcend...
Answered
on Jun 09, 2013
Unformat disk
Easily you can get back your files by using a data recovery program. For that you need to go online and search a data recovery software , you will get this software paid as well as free.
5/28/2013 10:04:59 AM •
Transcend...
Answered
on May 28, 2013
Storejet500gb transcend thus not appear
If the drive can be seen by device manager but not under My Computer, right click my computer and go to "Manage". (Check out: right clicking my computer icon on your desktop, select disk manager)You should see your hard drive either lister as foreign or not initialized. If foreign, it will give you an option to import and is not initialized, it will allow you to initialize it. This will hand over drive management to the OS and you should be able to see it in My Computer.Have you ever worried about
hard drive data recovery? Here is the solution:You can
recover data from hard drive with
data recovery software like Tenorshare Data Recovery. It can recover data after deeply scanning your hard drive to look for lost data. You can get it from:
http://www.any-data-recovery.com/index.htm
1/31/2013 2:43:29 PM •
Transcend...
Answered
on Jan 31, 2013
Hard disk is unable to
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this
hard drive recovery program called asoftech data recvoery to recover your files.
http://www.asoftech.com/adr/
1/31/2013 2:30:17 PM •
Transcend...
Answered
on Jan 31, 2013
