20 Most Recent
Toshiba NB305N410BN Netbook Questions & Answers
I can't seem to find
1. check the on device driver on device manger whether installed or not.
2. if the driver marked with exclamation mark then download the driver from the manufacture website
5/21/2019 3:00:48 PM •
Toshiba...
Answered
on May 21, 2019
Which keys lock the computer
There isnt a lock per-se. it might be sleeping. Tap the power button, if no response press and hold the power button. (Think toshiba wants aroud 5-7 sec. hold it for 10 just in case) this should shut it down completely.
Hit the power button again to turn it on.
8/8/2014 3:37:19 PM •
Toshiba...
Answered
on Aug 08, 2014
My Toshiba NB305 will not restart. What will I do?
Hi,Thanks for using fixya,
Remove the battery, and unplug the A/C adapter and hold down the power button, for 40 seconds.Soon your laptop will reset,and run well.Now you will install all the accessories and start.
Hope this helps you.
8/15/2011 7:56:49 AM •
Toshiba...
Answered
on Aug 15, 2011
My laptop is a toshiba .. this is the problem i
It could be playing from the site you were surfing. Try surfing again on the website you were accessing when you heard that song. If you hear it again from there, then it is not a virus.
Also make a full virus scan of your system just to be sure.
Thanks for using fixya!
5/30/2011 4:39:14 PM •
Toshiba...
Answered
on May 30, 2011
My Toshiba mini NB305-N410BL suddenly
Welcome to Fixya. To be able to provide you the solution to the problem may I know if the laptop is working if the battey is unplugged and your just using the AC adapter.
Thanks
4/9/2011 5:14:01 PM •
Toshiba...
Answered
on Apr 09, 2011
HOW CAN I PUT A DESKTOP BACKGROUND ON MY NB305?
1. Right click on a empty space on the desktop and click on
Personalize
Click on the
Desktop Background link at the bottom of the window.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
12/24/2010 1:32:04 PM •
Toshiba...
Answered
on Dec 24, 2010
Manual power off
To manually force the computer to turn off, press and hold the power button till it shuts down.
7/19/2010 4:16:43 PM •
Toshiba...
Answered
on Jul 19, 2010
No problem, just a question. Do I need to keep my
For the newer lithium batteries it is actually harmful to let them run down all the way, the optimal charge for battery life is at 40%,
The new lithium batteries do not have the memory problems that older batteries did, but they do still wear out.
The best thing would be to just plug it in when it needs charging, because leaving the battery at 100% charge at all times also reduces its lifespan.
3/12/2010 7:59:16 PM •
Toshiba...
Answered
on Mar 12, 2010
Trouble w/ removing memory module slot cover
omg!!! are you kidding me? HOW SILLY!! Anyway, don't worry about breaking anything.. You won't. #1 Make sure to remove the screw completely before trying to remove the plate. there should be a raised area or **** where you can slide a flatheaded screwdriver in to pull it up.. Try that and dont worry, k? JUST BE SURE TO UNPLUG AND TAKE THE BATTERY OUT BEFORE YOU DO ANY MAINTANENCE, OK? GREAT LUCK!! LUCKY4LYNN2 ps. PLEASE RATE ME, K?
3/7/2010 12:23:05 AM •
Toshiba...
Answered
on Mar 07, 2010
Reset to factory for toshiba nb 505 to factory out vof box
Restore Toshiba to Out of the Box ConditionIf your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on your notebook.2. When the machine Starts beeping; release the 0 key.3. When prompted by the warning screen; select Yes to continue with the systemrecovery.4. Select Recovery of Factory Default Software; click Next.5. Select Recover to out-of-box state. 6. Click Next again.7. Click Next to Start recovery. 8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
