20 Most Recent
Fire Sense 01775 Patio Heater Questions & Answers
Burner goes out after lighting and holding button for 30-45 secs.
It is usually the tipover sensor that is bad, I have had 2 of them bad right of the box. It is a black plastic peice, under the metal screen near the round know. It has 2 wires running to it, it is a saftey to shut off the heater if it tips over. to test it touch the two wires together, then try to light it, should lit no problem. Then contact manufacture for a replacement for it.
If this has been helpful, please rate the new guy :)
Contact me, If I can help you.
Sincerely,
Paul
Find the plastic replacement wheel for my fire sense patio heater?
I would suggest measuring the outside diameter of the existing wheel and also the diameter of the hole for the axle. Then maybe consider going to a Hobby Lobby or toy store to try to find a replacement. May even consider a second hand store like Goodwill and possibly find a cheap toy with wheels that will fit. You may be able then to change both of them so they match and maybe have another one or two to spare....... Good Luck!!!!
Manual light
My heater on my electric fireplace model BLT-999B-3 has quit working is there a replacement part available?
Can this unit be installed thru a wall with the sleeve/ box that comes with it? CW-XCI20AU
Obviously window and wall a/c units are not tradable, in spite of the fact that I don't have the subtleties of the distinction.
Alter Window units are intended to exploit the way that a window is a flimsy segment; vents outwardly of the a/c case can be near within part of the a/c unit, yet be outside (where they must be). This might permit the window units to be less expensive. Interestingly, a wall can be 6" thick or more; wall units should have all vents near the rear of the unit. BTW I generally felt that the vents in the side of a window unit were for admission of air at encompassing temperature to then be coordinated through the condenser curl at the back plane of the unit to be depleted out the back (presently more sweltering than surrounding), however as a matter of fact a portion of the side vent region may likewise be utilized for ousting air which cools engines. It may be the case that in a window unit the venting on one side is committed to admission of air for the condenser loop and the venting on the opposite side is for exhaust. This would forestall the hot exhaust air being pulled in the admission for the condenser cooling air.
Window ACs versus Through-the-Wall ACs
It's not difficult to think about window and through wall ACs, since they're comparative in cooling limit and size, yet through-the-wall units will generally be somewhat more productive in light of the fact that they make an impermeable seal in the room.
The significant contrasts between these ACs include establishment and venting. Window ACs fit through a window and don't need long-lasting establishment, while through wall ACs are really incorporated into the wall - making them well known in rooms without windows or for individuals who like to let their windows be.
Wall forced air systems normally just vent warm air through the rear of the unit, while window ACs vent from the sides and back. Hence, window and through wall models are not exchangeable (regardless of whether they're a similar size). Generally speaking, in the event that a window unit vents out its side, the wall will obstruct the vents and cause overheating. Select window AC models can be introduced through a wall, however provided that they have a slide-out case wall sleeve. Peruse more on wall sleeves.
3/25/2024 3:48:35 AM •
Heating &...
Answered
on Mar 25, 2024
Totaline p474 1050 thermostat reset
there is no rest. Item used 24VAC from hvac to power it . If 24VAC from hvac is missing thermostat will not power up and hvac will not work. You will need to call for service.
3/16/2024 5:20:55 PM •
Heating &...
Answered
on Mar 16, 2024
