20 Most Recent
Dayton 1DGX4 Dehumidifier Questions & Answers
For 3 yrs. the condensate
The hose may not be blocked, Ed. But the unit's hose connection and tubing may be.To solve the problem do the following:
Using an appropriately sized, 18" long, plastic
Zip Tie, carefully insert the tip of Zip Tie into the hose connection & tubing.
Continue to push it in until you reach a bend in the tubing. You will
need to gingerly work the Zip Tie past this bend, until it either
bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip
Tie back out while rotating (twisting) it. This will breakup any clogs.
As you reach the inserted end of the Zip Tie, be prepared, as some water
may follow. Reconnect the hose plug the unit in and turn the Master
ON/OFF Switch to ON. Set the humidity extraction level to 35% or
Maximum if you have a manually controlled unit. Allow the unit to run,
while you monitor the hose for water flow.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers.
I hope this helped you solve the problem. Thanks for choosing FixYa.
Whar does the E1 code suggest I do?
E1 indicates that the filter needs to be removed and cleaned. Be sure to turn the unit OFF and plug it, before removing the filter. You can either vacuum the filter or if it's really dirty, wash it in warm water and dish washing liquid, rinse and thoroughly dry it, before reinstalling it. NEVER operate the dehumidifier without the filter installed. Doing so could cause damage to the unit.
I have a Dayton 5eaj5
E3 error is for the humidity sensor needing service
E5 error is for the defrost sensor needing service
If it is under warranty, I would get it replaced.
8/2/2011 2:31:08 PM •
Dayton...
Answered
on Aug 02, 2011
