20 Most Recent
Danby DDR3009EE Dehumidifier Questions & Answers
Icing up recently.everyday it ices
The air intake filter may be clogged. Cleaning it, may solve the problem, once the unit thaws out. In addition, low refrigerant gas can also cause the unit to ice up. While waiting for the unit to thaw completely, turn the Master On/Off Switch to OFF and unplug the unit. In addition to thawing this unplugged time, may give the unit a chance to reset itself.
Hope this helped you solve the problem.
Dehumidifier doesn't turn on
The water in your sump pit needs to be no more than 2-3 inches, this is enough to keep your pump happy and make sure it works properly when you need it to. Equally, the pump should start to work when the water level is still 6-7 inches below the level of your floor. https://www.homoq.com/proper-sump-pit-water-level/
6/18/2021 4:49:02 AM •
Danby...
Answered
on Jun 18, 2021
My Danby dehumidifier leaks out
The drain tube or hole that drains into the bucket is probably clogged.
Turn the unit OFF and remove the bucket. Look in the cavity where the bucket was removed for a drain tube or drain hole. Using an 18" long plastic Zip Tie or something similar (No wire coat hangers) , that's appropriately sized to fit in the hole. Carefully feed the ZIP Tie into the hole or tube and thread it as far as you can. At some point the drain will curve, but you have to carefully get past this point. Once the Zip Tie has reached as far as it can, slowly pull it out while rotating it. This will loosen the clog. Once you have it half way out, be prepared for water to follow. This method should solve the problem.
6/26/2020 12:55:13 AM •
Danby...
Answered
on Jun 26, 2020
Why does my Danby DPAC9006 Portable AC fill up with water so quickly all of a sudden?
ac units work by removing water vapor from the air
That accounts for the water that is getting into the collector
now if the water volume is increasing , it can be from an increase in humidity of the air
portable units have to have an opening ( window or door ) to pass out the hot air and that allows more moisture laden air into the room. Maybe the next unit you get is fixed so that all of the doors and windows can be kept closed
7/27/2018 11:02:45 AM •
Danby...
Answered
on Jul 27, 2018
