20 Most Recent Kodak EasyShare C142 Digital Camera Questions & Answers
Camera freezes when I try to review pictur
My advice is to remove the card and back up the photos on a computer, then format the card from computer then from camera. Test, if it still freezes card is probably dead. Cheers
11/30/2014 9:36:51 AM • Kodak EasyShare... • Answered on Nov 30, 2014
0answers
Kodak c142
Be the first to answer 8/19/2014 3:15:51 AM • Kodak EasyShare... • Posted on Aug 19, 2014Be the first to answer
Memory card
I have seen elsewhere that the camera was not originally capable of handling a card larger than 1GB. But have also seen where it may be possible to update/upgrade the camera's firmwear to handle larger cards. The update would be available on Kodak's website. Here is a link to the user's manual if you need it. http://resources.kodak.com/support/pdf/en/manuals/urg01114/C142_xUG_GLB_en.pdf
8/5/2014 1:38:52 PM • Kodak EasyShare... • Answered on Aug 05, 2014
My SD high capacity memory card won't work
You call it a SD high capacity memory card, but does it say SDHC on the card, or SDXC. our camera only can use Multi Media cards, SD and SCHC cards (max 32 GByte). So no go for SDXC cards. Still a few things could be wrong if you have a SDHC card. The lock switch on the card could be in the wrong position and the card could have a wrong format. If you did format it in a PC, you should have formatted to FAT 32. But the best format is the format in the camera. Before you do so, be sure there are no import ants files or pictures on the memory card, because they will be lost.
1/1/2014 1:33:47 PM • Kodak EasyShare... • Answered on Jan 01, 2014
0answers
Lens obstructed
Oh dear. Unfortunately this is common with many lenses that extend and retract on these cameras. Fuji is also known to have similar issues. At some stage, the camera has been knocked while the lens has been extended. You may deny this, however - it doesn't take much to knock those little suckers out of alignment. Even as simple as putting it down on the table will do it! It cannot be fixed with 'layman' fingers and needs to be seen by a technician. Cost can be >$50 and may take a week or more to be returned...worse case - still UNFIXED!
11/26/2013 12:53:35 AM • Kodak EasyShare... • Answered on Nov 26, 2013
Will not work
Try to find out if there is something else obstructing the free movement of the lens barrel. And then try to find out if your battery (yes) are still ok. If they can't give enough power, the motor to drive the lens, can't work and the camera also "thinks" the lens got stuck. Sometimes, a gear that is involved with moving the lens became broke. If that happens, only a repair shop can help.
11/24/2013 9:39:36 PM • Kodak EasyShare... • Answered on Nov 24, 2013
Video sound
Do you hear the audio when you transfer the video to a computer and play it there? The camera itself will not play back the audio. See the NOTE at the end of http://resources.kodak.com/support/shtml/en/manuals/urg01114/urg01114c4s1.shtml
8/14/2013 2:30:02 PM • Kodak EasyShare... • Answered on Aug 14, 2013
Download 3x
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
8/8/2013 3:30:22 PM • Kodak EasyShare... • Answered on Aug 08, 2013
Power switch not working
hello sir .. does your batteries are charged already??if your batteries are fully charged and your camera didn`t turn on,there`s a possibility that your camera has a problem. You can visit the store where you bought your camera and you can ask questions there why does your camera didn`t turn on whenever your batteries are ok .. :)
5/17/2013 10:39:54 AM • Kodak EasyShare... • Answered on May 17, 2013
Change languagege
Press MENU, then use left/right to select the Setup tab on the right. Language should be the eighth item on this menu. Select it, and you should see "English" as one of the choices.
4/27/2013 3:22:59 PM • Kodak EasyShare... • Answered on Apr 27, 2013
Lens obstructed. remove lens cap
This is a fault of the camera Not your fault. The camera will require service / repair to correct this. Again, this is no fault of yours.
1/25/2013 4:20:15 AM • Kodak EasyShare... • Answered on Jan 25, 2013
Software does not work
What software are you referring to ? We can not guess.
1/24/2013 11:00:44 PM • Kodak EasyShare... • Answered on Jan 24, 2013
Why I cant insert memory card on my camera? its says the memory card is unusable(insert new memory card.)
Is it the right memory card for the Kodak C142, sounds like wrong card.
1/24/2013 9:47:16 PM • Kodak EasyShare... • Answered on Jan 24, 2013
Memory card unusable after downloading pictures kodak c142 camera
Hello Gerald, Do you mean after uploading the photos to your PC ? Try to format the card using the camera set up menu and see if this helps, sounds like the card got corrupted during the upload.
1/24/2013 6:45:36 PM • Kodak EasyShare... • Answered on Jan 24, 2013
Kako da postavim datumi vreme na slici na kodaku c142
Can Not Translate
1/24/2013 6:54:49 AM • Kodak EasyShare... • Answered on Jan 24, 2013
Instructions
You may view/download the extended user guide here.
1/13/2013 3:56:03 PM • Kodak EasyShare... • Answered on Jan 13, 2013
Kodak EasyShare C142 Digital Camera Logo
95 questions posted
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
instructions
  • Cameras
